Rear Drums to Discs - FFCars.com : Factory Five Racing Discussion Forum
Old 02-26-2004, 07:32 PM   #1 (permalink)
Got a set of rear caliper brackets off Ebay for 50 bucks! These are the same ones used in most conversion kits I have investigated. Can anyone provide information on discs and calipers that will work on a stock 8.8 4-lug rear axle conversion? Will a set of 84 T'bird Turbo calipers and discs work?
[img]graemlins/gocart.gif[/img] [img]graemlins/silver.gif[/img] [img]graemlins/white.gif[/img] [img]graemlins/red.gif[/img]
FFR2740K, Stock 5.0, Red with White stripes, Custom Console.
Does anybody realize in 40 years we will have thousands of old ladies with tattoos running around?
Tnarchtct is offline
Old 02-26-2004, 08:07 PM   #2 (permalink)
Kobra4Kris's Avatar
If I'm not mistaken I beleive there are a few different types of brackets which all use different types of calipers. You should ask whoever you got it from just to be sure. I used Northracecars brackets and they require the rear calipers and discs from 94 up (SN95) Mustangs.
I'm sure others will add their input as well.
FFR1003892RD MKIII Arrived on 4-13-04..First ride in Go Kart 6-27-04. First production MKIII to be on the road and street legal... 7-16-04!!!
Check out: MyKobra.com
Non-Donor, Crate 302, Vortech Strim, Custom Built C&S Blow Thru Carb, Air Gap Intake, T5, 4 Whl. Discs, Hallibrand Cobra III Wheels 17x9 & 17x10.5.
"She might not look like much, but she's got it where it counts kid" -Han Solo
Kobra4Kris is offline
Old 02-26-2004, 10:11 PM   #3 (permalink)
Kobra4kris is correct. I got mine from the same place. Mine are for the Cobra 10.65" rotors and, logically, you would require a different bracket if you were using the smaller T'bird rotor.
I suggest that you visit North Race Cars web site (they are supporting vendors) or contact Richard via email: Richard@northracecars.com . He does know his stuff.
Hank J.
Hank J is offline
Old 02-26-2004, 11:50 PM   #4 (permalink)
oldman ohio's Avatar
Richard oben can answer your questions and also furnish you with the brackets that you will need for the conversion. Also e-brake cables.
jack
Almost every time I sneeze, cough or sputter, either my radiator leaks or my exhaust backfires.
At my age, food has replaced sex . Now I'm so fat that I can't even get into my own pants.
oldman ohio is offline
Old 02-27-2004, 01:47 AM   #5 (permalink)
BillKnight's Avatar
Rich Oben gets my vote here! He can help!
KB,331,AFR185,PIN drive,IRS,steering wheel.
BillKnight is offline
Old 02-27-2004, 02:17 AM   #6 (permalink)
Thanks for the advice!
Old 02-27-2004, 03:10 AM   #7 (permalink)
Tnarchtct:
Take a look at attached site and it may give you an idea of what you will need to convert from drum to disks for the rear.
http://www.ssbrakes.com/products/det...tang&year=1990
Hope that this helps.
Allan [img]graemlins/black.gif[/img]
FFR3822 - Currently Under Construction
Misu is offline
