The next issue with my F250 - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 3 (permalink) Old 04-20-2017, 07:51 PM Thread Starter
USMC's Avatar
I went underneath to give it it's annual wash the salt off bath. It appears the supports for the driver running board needs replacing.
This stuff isn't cheap! Unless someone knows of an inexpensive place for Ford body parts. I had the same issue with my wife's Explorer stupid little brackets would cost $50 each and you end up needing several. It seems doesn't do a good job preventing corrosion on things like brackets.
It's also the type of thing you can't just go to the upickem yard because anything in there is likely to be just as corroded.
USMC is online now
post #2 of 3 (permalink) Old 04-21-2017, 12:17 PM
skunkman's Avatar
How did you get salt on your truck?
If you don't think it's real, go ahead and step in front of it!
mark III, 302 crate, 670 Holley carb, 3 link, non-donor.
skunkman is offline
post #3 of 3 (permalink) Old 04-21-2017, 02:06 PM Thread Starter
USMC's Avatar
Drove over a plate of corn on the cob.
USMC is online now
