hot water heater leaking. - FFCars.com : Factory Five Racing Discussion Forum
Old 10-04-2012, 10:35 PM   #1 (permalink)
skunkman's Avatar
I had both of my hot water heaters replaced about 18 months ago. They are in the garage. Today I went into the closet where they are stored and I noticed about an inch of water in the plastic tray under BOTH heaters. Is thisnin any was normal?
If you don't think it's real, go ahead and step in front of it!
mark III, 302 crate, 670 Holley carb, 3 link, non-donor. http://www.ffcars.com/forums/17-factory-five-roadsters/209511-please-graduate-ffr-6137-skunkman.html
skunkman is offline   Reply With Quote
Old 10-04-2012, 10:58 PM   #2 (permalink)
A decent water heater should last about 10 years. If you have a failure before that, it's probably not the water heater. Especially if two of them fail at the same time.
Old 10-04-2012, 11:00 PM   #3 (permalink)
Thanatopsis's Avatar
I blame it on the zombie in the crate.
“Debugging is twice as hard as writing the code in the first place.
Therefore, if you write the code as cleverly as possible, you are, by
definition, not smart enough to debug it.” -- Brian Kernighan
Peace,
Dave
Thanatopsis is offline   Reply With Quote
Old 10-04-2012, 11:21 PM   #4 (permalink)
jchigley5's Avatar
From experience, this is usually caused by too much water pressure. Also, make sure they have expansion tanks. It would be leaking out of the t&p valve.
4.6L SOHC - 4 Link 3.55 Gears - Orange Pearl - Auto Trans
jchigley5 is offline   Reply With Quote
Old 10-05-2012, 12:09 AM   #5 (permalink)
THRAMP-master
bwana50's Avatar
Unusual, but not impossible. We moved into brand-new base housing once, and the water heater sprang a leak about 6 months later.
FFR3639. 5.0L + Paxton Novi 1000 = 368 RWHP. Need more twisty roads in Kansas...
bwana50 is offline   Reply With Quote
Old 10-05-2012, 01:47 AM   #6 (permalink)
Cobra Cory's Avatar
Yep definitely get expansion tanks and check your water pressure.
Look into Marathon heaters. Much better and more efficient than the regular steel tanks.
Marathon Water Heaters
Also check with your electric company and see if they give you a special rate on buying a Marathon heater. I know ours does.
http://www.nhec.com/filerepository/m...ist04_2010.pdf
Of course that is if you have electric ones.....
Cobra Cory is online now   Reply With Quote
Old 10-05-2012, 10:45 AM   #7 (permalink)
Hoosier's Avatar
Not normal....
Good news is they all have 5 to 10 year warranties on the tanks so if that is the issue, at least the heater itself is covered under warranty...labor, not so much.
It could be:
Leaking Tank
Leaking around heating element(electric heater)
Too much pressure causing T&P valve to release
Too much heat causing T&P valve to release
Faulty T&P valve
The addition of an expansion tank is a necessary item in this day and age. As the heater heats, pressure is created. If there is a check valve somewhere between your heater and the utility company's water main, there is nowhere for this pressure to be released causing the T&P valve to open so as to release the excessive pressure.
-Andrew-
Hoosier is offline   Reply With Quote
Old 10-05-2012, 11:04 AM   #8 (permalink)
trevor's Avatar
Can be all those problems listed in addition to very acidic water. If you are on a well I would get the water analyzed.
trevor is online now   Reply With Quote
Old 10-05-2012, 11:29 AM   #9 (permalink)
tim-in-oakton's Avatar
Locate the leak first, it is not unusual to tie both tubs together to a single (clogged) drain so you may not have two leaks. I'm going to bet on a single leak from an installation issue - keep us posted
FFR 5736, MKIII, 3 link, PS, PB, 302 w GT40 heads & intake, 3.55, Cobra brakes
tim-in-oakton is offline   Reply With Quote
Old 10-05-2012, 12:23 PM   #10 (permalink)
skunkman's Avatar
Thanks for the input - I'll check into it tonight. I don't think there is an expansion tank on the units.
mark III, 302 crate, 670 Holley carb, 3 link, non-donor. http://www.ffcars.com/forums/showthread.php?t=209511
Old 10-06-2012, 02:18 PM   #11 (permalink)
BigLeo69's Avatar
Icon21 relief valve
check it by pulling up on it. the tank may have too high of a setting for temp.
sometimes the relief valve blows and will show water. its doing its job but they can fail and get stuck with debris.
one big thing is type of water in your area.
St. louis we got some good sh!t here so tanks last along time, some use dielectric fittings i think they suck, the Galv. fitting will oxidize the iron pipe into the tank.
the best way is to go from the copper supply to brass then to the tank fittings.
the dielectric actually will oxidize inside and slow the supply water pressure, i have seen it many times and have spoke to many plumbers over the years about it.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
