Holley carb recommendation, two hole or four hole idle? - FFCars.com : Factory Five Racing Discussion Forum
Old 10-02-2012, 12:01 AM   #1 (permalink)
J Persons's Avatar
I'm pretty much settled on a 750 double pump, Holley shows models with either primary idle adjustment or another model with idle adjustment on all four corners. This will be used on a Edel Vic jr. Engine is a Dart block 363ci. I've always used just the primary idle adjustment type, is the four corner idle adjustment worth it?
J Persons is online now   Reply With Quote
Old 10-02-2012, 12:55 AM   #2 (permalink)
Supporting Vendor & Admin
Wayne Presley's Avatar
I'd go with a Quick Fuel SS-750 AN carb over the Holley. It has billet metering blocks, billet baseplate, and every jet is adjustable. I sell them for $565, sold one last week for a 402W in a Backdraft and the guy loves it. Said the car has never run better.
Wayne Presley
www.verycoolparts.com
Old 10-02-2012, 04:26 PM   #3 (permalink)
i used a 750 holley ultra hp on a 351 crate engine and very happy. adjusted the idle eze and lowered the floats and haven't touched it. very nice features also. has the 4 corner idle btw.
vector1 is online now   Reply With Quote
Old 10-02-2012, 05:05 PM   #4 (permalink)
FFR Master Craftsman
Greg_M's Avatar
Really depends on your cam and engine. IMO the 4-corner idle is used to adjust the idle mix on the secondaries if you have to open them up with their curb idle screw to compensate for too much T-slot showing under the primary idle plate due to a big cam.
Most times idle is set only with the primary throttle stop and the primary idle mix screws.
Does your car idle OK now with a 2 corner setup?
Miss August 2007
Miss December 2012
Miss TR6 June 2013
The blues brothers
Old 10-02-2012, 05:42 PM   #5 (permalink)
Too bad the Ultra HP's cost $720, less features for more money over the annular Quick Fuel
Wayne Presley
Old 10-02-2012, 07:05 PM   #6 (permalink)
Holley Performance Products 750CFM Hard Core Gray™ with Black Billet, Aluminum Ultra HP*0-80803HB
don't know what you are looking at but here is the one i bought. well worth the money.
Old 10-02-2012, 11:49 PM   #7 (permalink)
Cone Basher's Avatar
Talking
I have a Holley HP pro series carb on my car which I run in Auto-x events and the only thing I can add to this discussion is if you ever want to run an Auto-X event make sure the carb you get has road race floats, I had to add them to mine. I like the Holley HP on my car but it has a milled choke horn and takes a bit of warm up before it idles well. Great performance carb, 4 corner idle, jets easy to change etc. I definitely recommend a dp carb if you are running a single plane manifold.
CB
Old 10-03-2012, 01:15 PM   #8 (permalink)
I would go w/ 4 corner idle. My friend just got one of the Holley double pumpers w/ the idle ease setup. He was having a hard time getting the idle below about 1400 as it arrived and ended up w/ some combination of changing the idle stop screws on both primary and secondary. Of course he had to deal w/ the proper transfer slot adjustment too.Needing to change the idle stop adjustments on both sides tells me it's good to have idle mix adjustment capability for both sides too.
Old 10-03-2012, 02:41 PM   #9 (permalink)
Greg_M's Avatar
I just dropped on a Holley 4776-7 600DP (2 corner idle) and to my surprise it runs, idles, and transition perfectly out of the box. The only change I made was to lean the secondaries from #73 to #70 to maintain 12.2 AFR at WOT to 6,000 rpm. Lean cruise is perfect at 13.6 to 14.7 AFR between 15" and 6" of vacuum. I run down the highway at 70 mph keeping mid 14's AFR for great mileage. The throttle response is crisp and hits hard when I stomp it. It can run at 1,200 rpm in 5th and pull flawlessly with moderate throttle. If I floor it at 1,500 rpm in 5th it does not stumble or bog. Pretty amazing.
Miss August 2007
Miss December 2012
Miss TR6 June 2013
The blues brothers
