Question on finishing of wood with Minwax® Polycrylic® Protective Finish - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 9 (permalink) Old 03-30-2010, 02:16 AM Thread Starter
accobra66's Avatar
I am in the final stages of building a new coffee table. Long story short, I built the table out of maple and pained the bottom legs, frame, etc. with white paint. That all came out to my liking.
The top of the table is maple as well and I chose to use Minwax® Polycrylic® Protective Finish. The issues I am having are:
1.) Seem to have debris in the finish (little dust or dirt dots littering the surface after sealing). I followed the directions on the can (sanded with 220), removed dust with tack cloth and then followed up with a damp paper towel. Once this did not work, I went back with a heavier grade paper, then came back to 220. Same thing, still have the spots. Thinking that I did not sand down far enough to remove them.
2.) Top of the table is approximately 40" x 24". When laying down the sealer, I am finding that I am not getting an even finish. Some spots are glossy with a nice smooth finish, other spots seem "thin" where it does not seem like I put enough product down. The can says to apply thin coats, but when I do I seems as if I had put more product down it would have come out glossy and smooth like I am looking for.
Notes:
1.) Using high quality synthetic brush as can directs me to.
2.) Brushing in one direction while trying not to "over brush"
Questions:
1.) Other than the above problems/possible solutions I am looking for, should I try using a sponge brush? Would this apply a more even, smooth coat?
Carbed 351W w/Levy Racing Super Alloy T-5; Levy 5-Link rear suspension w/ Street Bump Steer; Pin-drive; powder coated frame and heated seats.
accobra66 is offline
post #2 of 9 (permalink) Old 03-30-2010, 03:03 AM
osomxl's Avatar
Are you using a new can?
Is your brush clean?
I have seen new brushes with a little bit of grit in them and will wash them prior to using.
I would also suggest that you look in the can and see if you can see particles.
You may need to strain the polycrylic.
I dont like using the foam brushes as they seem to leave small bubbles in the finish and you end up over brushing trying to get rid of the tiny bubbles.
You may have better results if you thin the clear slightly.
I would recommend loading the brush with the finish fairly good and use smooth, slow, even strokes and make sure that you overlap the last brush stroke about 50%.
Finally, I would like to remind you that you will need to do several coats-
1- build up several coats and then wet sand or;
2- do a coat and let dry according to directions and then lighty sand with 220 and then repeat until you are satisfied and finish of with 400-600 grit for a super slick finish.
osomxl is offline
post #3 of 9 (permalink) Old 03-30-2010, 12:42 PM
THRAMP-master
bwana50's Avatar
I'd bet that your paper towel is leaving paper lint on the surface. Tack cloth should be the last step before applying finish.
FFR3639. 5.0L + Paxton Novi 1000 = 368 RWHP. Need more twisty roads in Kansas...
bwana50 is offline
post #4 of 9 (permalink) Old 03-30-2010, 01:57 PM
ruffone's Avatar
Are you sanding the surface smooth between coats or are you waiting to sand the finish until all coats are applied? If you don't sand the surface between each coat you will get particles stuck between each coat. So I am going to say that you probably haven't sanded deep enough if that is the case. I always get dust particles on the guitars I build in between the finish coats hence why you sand between each coat. Also, to save you future headaches, spend the cash on a high quality waxing towel to wipe the finish down after you use the tact cloth. (It won't leave the particles that the paper towel does.)
Also, I have used that minwax product many times and I have come to the conclusion that you have to apply a thicker coat then what they suggest when using a paint brush to get a smoother even finish with it. People may argue, but that is what I have learned from using the product.
ruffone is offline
post #5 of 9 (permalink) Old 03-30-2010, 01:59 PM
hoofa's Avatar
Don't use a brush or roller, use one of those flat pad thingies. If your using a satin finish use gloss for the first coats then satin for the final otherwise it will end up kinda cloudy.
Posted via Mobile Device
hoofa is offline
post #6 of 9 (permalink) Old 03-30-2010, 04:50 PM
hoofa's Avatar
hoofa is offline
post #7 of 9 (permalink) Old 03-30-2010, 06:21 PM
Brian F's Avatar
When using Minwax, I do multiple coats (such as 5 - 10) and do very thin coats. Worked well so far...
Non-Donor MKIII Delivered Oct. 18, 2005
Complete June 21, 2006
351w 400hp, T5, 3-link, 3:55
Brian F is offline
post #8 of 9 (permalink) Old 03-30-2010, 07:15 PM Thread Starter
accobra66's Avatar
What I am finding is that when I do "thin" coats, I have brush marks.
1.) Do you do the thin coats one after another or after each coat cures? Can says to cure so I would think that is correct.
I tried putting on two heavy coats this morning (one after another) and that has produced the best results yet but still not the way I want. RRRRR
post #9 of 9 (permalink) Old 03-30-2010, 07:48 PM
BigLeo69's Avatar
Wink
is it gloss, semi-gloss or satin
i prefer satin because on a table the finish will polish itself over time and shows less imperfections.
you need to use a different paint pot, do not work out of the can.stir don't shake varnish
first coat i normally thin a little and fine sand between with 4 ought (0000)
steel wool or a scotch brite. you can make your own tack rags with varnish on cheese-cloth let sit for an hour or 2 after squeezing out. or buy them.
after sanding between coats wipe down and apply 2nd coat at recommended time frame. you can strain the varnish with a womens stocking see if your neighbor has any of your wives
the other trick to a good finish is the brush and its size. a top i would use a 3-4 inch china-bristle a good Purdy brand, they don't come cheap and make sure you clean it well so it can be used again.
Good Luck
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
BigLeo69 is offline
