Why does my oven smell like gas when I first turn it on? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 6 (permalink) Old 12-13-2009, 04:07 PM Thread Starter
USMC's Avatar
For about the past month (i.e. this is a new problem) whenever I turn my oven on I get a very strong gas smell in the house for the first half hour or so. It seems to light right away and the smell goes away after the oven has been on a while.
Anyone know what causes this and what I may need to do to fix it?
USMC is online now
post #2 of 6 (permalink) Old 12-13-2009, 04:34 PM
BS
Usually, I would give you some advice on what needs to be looked at, but in this case I would recommend getting an appliance repair man who knows gas appliances to look at it. Gas leaks/malfunctions aren't for the amateur to mess with IMHO.
Built an original style CSX 427SC frame/body car with Carbon fiber body, 393W stroker, T5 (for now), T-bird IRS w/3.27 gears, dual roll bars, and lots of decisions yet to make.
BS is offline
post #3 of 6 (permalink) Old 12-13-2009, 04:40 PM
MichaelWhaley's Avatar
I agree on getting an expert... and it reminds me of a joke: A skydiver was falling to earth and his chut wouldn't open. As he was falling he noticed a guy shooting up from the ground toward him. As they passed each other the sky diver yells "hey, do you know anything about parachutes?", and the guy from the ground yells back, "No, but do you know anything about gas stoves?"
MkIII Roadster, IRS, Levy Racing 351w Mass Flo EFI, TKO 600, Grad. Oct. 2006.
Type 65 Coupe, IRS, Levy Racing 347, HD T-5, Wilwood brakes, Grad. May 2010 (sold Aug 2012)
You have the right to life, liberty, and the pursuit of hoppiness!
MichaelWhaley is offline
post #4 of 6 (permalink) Old 12-13-2009, 08:52 PM
The Italian's Avatar
You probably have a a heating element that is going bad
Many have an element(like a glow plug) that gets red hot and ignites the gas.
It may quit working soon as the element will burn a fuse being on too long.The parts can be replaced yourself (if you built your car)it's not hard , but sounds like it is OLD?
There is 3 parts that should be replaced if you plan on keeping it
I would tear out the old kitchen and replace the cabinets and all appliances and imported granite
"FOR THE FIRST TIME IN MY LIFE ,I AM PROUD OF MY COUNTRY"...2008 M.O.
The Italian is offline
post #5 of 6 (permalink) Old 12-14-2009, 12:06 AM
You guys never fail to crack me up. That is exactly the sort of mind set we all seem to have.
I'm going to change the oil in the car and *bam* it's seven hours later, the oils isn't changed but the interior has been detailed and I've rearranged the garage looking for the ramps and oil drain tub.
watermoccasin is offline
post #6 of 6 (permalink) Old 12-14-2009, 04:12 PM
Delivered
Mike_R's Avatar
My oven has starting doing this as well. During the pre-heat it smells like the gas isnt being completly burnt.
FFR# 6281: 351w, Vic Jr. heads, 10.5:1, xe288hr cam. IRS.
First start: Nov. 08
First go gart: Nov. 08
Mike_R is offline
