Call me hard headed...... I can see this radiator probably not working under the worst conditions. But, under the conditions you are working under, it dont make sense (to me).
Id certainly experiment with a 180 since you are running a carb.
Based on what you said several posts ago, you have your fan set to come on at 180 and you have a 195 thermostat. That means your fan will always come on before the thermostat opens. This means your fan will run 100% of the time.
Ideally, it should be the other way around. your thermostate should open at 180 and the fan come on at 195.
earl
See all of the "COBRAEARL's Creature Comfort FFR Accessories" HERE!
