Graziano Gearing and Drop Gears - FFCars.com : Factory Five Racing Discussion Forum
LinkBack Thread Tools
Old 04-19-2017, 02:39 PM   #1 (permalink)
I put this post together on the SLC board (Graziano Gearing and Drop Gears - GT40s.com) to help others avoid the pitfalls I've encountered with my Graziano L140 - transaxle from the Ausdi R8, Lamborghini Gallardo and some others. There's a huge amount of misinformation out there about gear ratios (including Audi's own product guides) and all aspects of a drop gear solution - in particular their impact on ratios/engine rpm and ease of install.
This post has been over a year in the making - starting with when I ordered my 2014 R8 Gearbox (Audi code: KBA). Shortly after it arrived I realized the gearing in it didn't match Audi's published materials. What was supposed to be just a nuance of my Superlite Coupe project took on a life of its own. Getting to the answer wound up involving more effort than I'd like to admit - hours and hours of research, conversations with the Audi Executive responsible for the R8's launch, more conversations with the lead engineer in Germany and ultimately installing a set of drop gears on my transaxle and driving the car.
In short - there's a transfer gear in the transaxle. It's the gear set the drop gears replace and it has a ratio of 1.32.
Audi materials don't disclose this gear, and Audi represents different ratios in its early product guides than it does in its later product guides. This was news to the folks at Audi when I brought it to their attention.
In short - the ratios represented in the early materials are effective gear ratios; they incorporate the transfer gear ratio into the number shown. The later materials represent the ratios of the actual gears themselves and make no mention of the transfer gear. For the purpose of swapping gears, it makes sense to work from the actual ratios. For simplicity, for the V-8 version of the R8 Graziano, they are:
1st - 3.31
2nd - 2.05
3rd - 1.42
4th - 1.07
5th - 0.85
6th - 0.7
Transfer - 1.32
What this produces is great for the low torque, high revving Audi motor - not so much for the LS motors, particularly for street use where 1st gear is far too short (37mph) and 6th gear has you sitting at about 3400rpms on the highway at 80mph. I've attached a gearing model to this post for my car showing rpm and speed for each gear.
The solution available thus far has been to swap for a .76 ratio transfer gear. It's been advertised this drop gear:
1. will produce about a 240mph top speed,
2. highway cruise at 2500rpms
3. is an easy, 30 minute install once the gearbox is apart
I bought one of these gear sets, had them installed by a well-respected Ferrari shop familiar with Grazianos and learned the hard way this is all wrong. During install, I learned changing the transfer gears require the entire gearbox to come apart, every gear to come off the shafts and a portion of the case to be machined - hardly a 30 minute job. After driving the car (I believe mine is the first set actually installed and in a car that's been driven) I realized the impact of the .76 drop gear is much greater than advertised. Try a 302mph top end and highway cruise at 1800rpms. Gearing model attached.
Now these gears aren't all bad; they're actually just slightly taller than the factory Ricardo gearing. For someone building a high horsepower car, or one they want to have similar gearing to that of a production Corvette, they are great - but they're not what's being advertised on any level. I've learned subsequently this 0.76 ratio set was developed for the 1,000hp+ Twin Turbo Gallardo guys who wanted to run the Texas Mile. With a higher horsepower car or that type of application, this set is a good fit.
For me, though, with the 525hp LS376 motor in a car I plan to drive on road courses and on the street, it's not such a great fit. When I drove the car with the .76 gears the gearing felt too tall - acceleration didn't impress with my horsepower level and 6th gear became unusable. To match what I was looking for I needed something closer to a 1.038 ratio... so I commissioned having them made. They produce what the other gear was originally advertised to do - the 2500rpm highway cruise, a reasonable 1st gear (47mph) and a 221mph top speed. Gearing model attached.
MOD EDIT: Content removed for BOR group-buy non-compliance.
Best,
PS Gear calc files - https://drive.google.com/open?id=0B9...G5odGpNNFVEbzg
File Type: xls Gear calculator Graz V8 - .76 gears.xls (36.0 KB, 11 views)
JBurer is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 03:17 PM   #2 (permalink)
John,
Great info, thanks for all the research and for posting it for others.
The gearing is one of the reasons I went with a Mendeola.
SL-C in progress....
dallas_ is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 05:11 PM   #3 (permalink)
ARROWSTEEL's Avatar
Just curious what was the cost of the new trans and what will the final transaxle cost be when geared for your LS engine.
ARROWSTEEL is online now   Reply With Quote Quick reply to this message
Old 04-19-2017, 08:42 PM   #4 (permalink)
It really all depends on how you source the trans. About 6 channels to get them - the channel I chose for my personal transaxle was not the most cost effective. Email is JBurer at yahoo if you'd like me to elaborate.
Best,
Old 04-19-2017, 09:29 PM   #5 (permalink)
PSB
PSB's Avatar
New Graziano purchased from Superlite (although I don't think they will sell one without buying a kit from them) is $10K, plus $2K for the clutch and custom flywheel. Add another ~$3K for the drop gears and install.
Pete
Race Car Replicas Superlite Coupe
Hunter Kit Cars #37 - SOLD
PSB is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 09:50 PM   #6 (permalink)
www.myraceshop.com
The Mendeola at $8,000 with any gears you want is looking better all the time!
TRANSAXLE MODELS
GTM/Corvette/Racing Parts
crash is online now   Reply With Quote Quick reply to this message
Old 04-19-2017, 11:52 PM   #7 (permalink)
TRANSAXLE MODELS
Crash - is that for the 5 speed, 400hp box?
Insurance
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
2017 London Cobra Show...
Today 06:40 PM
Last post by FACTORYFIVERACING
Today 06:43 PM
3 Replies, 17 Views
Are the Casey Design...
Yesterday 01:06 AM
Last post by CraigS
Today 05:55 PM
5 Replies, 273 Views
Fan relay wiring...
Today 02:32 AM
by jeepurz
Last post by CraigS
Today 05:54 PM
5 Replies, 97 Views
GlenH's MKIV Build ( 1 2 )
04-05-2017 05:18 PM
by GlenH
Last post by GlenH
Today 05:48 PM
49 Replies, 2,108 Views
Hi
06-21-2017 05:45 PM
by B Fry
Last post by B Fry
Today 05:40 PM
8 Replies, 182 Views
Brake Line Tee
06-21-2017 07:18 PM
Last post by daltmcintyre
Today 05:15 PM
11 Replies, 528 Views
Holley Red Fuel Pump
Today 04:44 PM
Last post by wickershaw
Today 04:44 PM
0 Replies, 28 Views
Disc brakes R us?
Today 02:39 PM
by raceral
Last post by Michael Everson
Today 04:27 PM
3 Replies, 77 Views
Flowmaster Slimlines...
05-28-2017 10:48 PM
by AdamC
Last post by steno
Today 04:14 PM
11 Replies, 452 Views
Radiator cover
06-24-2017 04:01 PM
Last post by John Dol
Today 03:44 PM
3 Replies, 139 Views
Inventory help please
Yesterday 03:48 PM
by Rychi1
Last post by DadofThree
Today 03:38 PM
3 Replies, 117 Views
The Official FFR Top Dog... ( 1 2 3 4 )
01-25-2015 09:36 AM
by jimgood
Last post by crash
Today 03:33 PM
92 Replies, 5,621 Views
Barrett Jackson
Today 12:52 PM
by casedoc
Last post by casedoc
Today 03:26 PM
2 Replies, 97 Views
Is it me, or is life...
06-22-2017 03:55 PM
by ROB J
Last post by Irwin Ayes
Today 03:13 PM
14 Replies, 360 Views
WERC Round #3
Today 02:58 PM
by crash
Last post by crash
Today 02:58 PM
0 Replies, 19 Views
FFR 8551 289 kit has...
Today 02:50 PM
by DrBrian
Last post by DrBrian
Today 02:50 PM
0 Replies, 36 Views
Calgary guys -...
06-15-2017 03:43 PM
by obrienj
Last post by obrienj
Today 02:38 PM
4 Replies, 109 Views
Win this Cobra
04-17-2017 03:43 AM
by R Edgar
Last post by R Edgar
Today 02:05 PM
6 Replies, 479 Views
Converting a three way...
06-21-2017 02:12 PM
Last post by USMC
Today 01:16 PM
13 Replies, 272 Views
Electronic Stability...
06-23-2017 07:25 PM
Last post by JIM Young
Today 11:56 AM
15 Replies, 408 Views
Google
Roadster Forum
4.6L Roadsters
Big Block Roadsters
Non-Ford Powered Roadsters
GTM Forum
GTM Classifieds
GTM FAQ
'33 Hot Rod Forum
Hot Rod Classifieds
Challenge Cars
Road Racing
Autocross / Pro Solo
Drag Racing
Free Photo Hosting
Tires / Wheels
Tops & Tonneaus
Upholstery
Gallery
Audio / Electronics
Car Care
Insurance / Registration
Brakes / Suspension
Ford Big Block Tech
Ford Small Block Tech
Forced Induction / NOS
Fuel Injection Tech
National Events
Southwest
Northwest
NorCal
SoCal
Southcentral
Midwest
Southeast
Northeast
Canada
Off Topic Discussions
Other Car Discussions
Smyth Performance G3F
Parts For Sale / Wanted
Donor Cars For Sale / Wanted
FFCars.com News
Forum Help / Test
