Electrical question re: radiator fan relay with A/C - FFCars.com : Factory Five Racing Discussion Forum
Thanks Tree9Thanks
  • 1 Post By daveS53
  • 1 Post By bobquincy
  • 1 Post By daveS53
  • 1 Post By daveS53
  • 1 Post By daveS53
  • 1 Post By Shane
  • 1 Post By DIY
  • 1 Post By Shane
  • 1 Post By daveS53
LinkBack Thread Tools
Old 03-18-2017, 11:17 AM   #1 (permalink)
I have the Vintage Air A/C with a trinary switch. I need to run a blue wire from the trinary switch to the radiator fan relay according to VA schematic. I have an LS3 crate engine with custom GTM harness from SMC Performance. There are two radiator fans with two relays. VA tech support told me to run the blue trinary wire to one of the engine coolant temp sensor wires (he wasn't sure which one) to activate the fans if the A/C pressure gets too high. SMC Performance doesn't think this is correct since this signal from the trinary A/C switch will then be telling the ECU that the engine is running hot and therefore the fans need to be switched on and this could affect ignition timing. SMC suggests running a "ground wire" from the trinary switch to one of the wires in each of the fan relays to activate them that way. I don't have the electrical background to know what needs to be done here. Has anyone else had this scenario? Any help would be appreciated!
Thanks!
Keith
Keith1 is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 01:59 PM   #2 (permalink)
daveS53's Avatar
The VA person is wrong. You would never run a wire from the trinary switch to an LS3 temp sensor. That's because modern temp sensors produce a varying VOLTAGE output that corresponds to a range of temps. The ECU sends out a 5V signal and the compares the returning voltage from the temps sensor to determine the coolant temperature. The lower the voltage, the higher the temperature. Some old-style temp sensors may be nothing but a grounding switch that is turned on when the engine reaches one specific temp. In that case, the VA suggestion is appropriate.
http://www.ls2.com/boggs/dtcs/DTC%20P0118.htm
The wire that runs from the trinary switch to the fan relay is a ground signal that engages the relay. The suggestion from SMC makes more sense. It's just what I mentioned in my earlier post, as one possible way to turn the fans on.
I would ask where these relays are located and whether you can trace the proper wire on the relays to connect with trinary switch. If you unplug one of the relays, look for the terminals marked 85 and 86. One wire will be positive and the other negative. It's common for 86 to be positive, but it's not guaranteed. If it is, you may find that it also connects to the wire routed to terminal 30, that will have +12V to it whenever the ignition switch is in the run position. The wire from terminal 87 should be the +12V wire to the fan. Terminal 85 would then be connected to a -12V (ground) and that's where the relay wire (blue) from the trinary switch should be connected.
Here's video that explains a standard 5-pole relay.
Keith1 thanked this.
daveS53 is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 02:07 PM   #3 (permalink)
A temp sensor provides a varying resistance to the ECM, grounding the signal through the trinary switch would probably tell the ECM that the sensor has failed.
As far as I can tell the trinary switch is designed to interface with an ECM and is not intended to directly drive a relay (although some builders have done it and it works, at least for awhile). I would connect a solid state relay (Del City has some) to the switch and drive the fan relays from the solid state relay.
More $$$ and wiring but more robust and in keeping with the design intentions of the trinary switch.
bobquincy is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 02:18 PM   #4 (permalink)
daveS53's Avatar
If you watch the VA video you will realize that the trinary switch that they sell is designed to work with an ordinary 5-pole automotive relay. You're overthinking this problem. Their systems are made to work with older cars that have no ECM.
Old 03-18-2017, 03:07 PM   #5 (permalink)
Thanks for the responses guys. I checked the relay for the two fans. The wiring is:
First relay:
30--Red
87--Red/Blk
85--Pink
86--Grn
Second relay:
Same as above with the only difference at pin 86, where there is a blue wire.
Can I assume that its the Grn and Blu wires that I need to tap into with the blue trinary switch wire? There is a mesh loom that the custom harness is encased in so I can't trace the wires.
The wires coming from the coolant temp sensor are yellow and tan, so neither of them is going to the fan relays. I assume that goes to the ECU and the ECU must send a signal to the relays.
Old 03-18-2017, 03:29 PM   #6 (permalink)
Without the specifications we don't know what the switch is designed for. VA probably buys an off-the-shelf switch that is designed for a modern AC system.
24 years of designing electrical systems for construction equipment can make one tend to be cautious about these things.
Trinary switch tech video - YouTube
Old 03-18-2017, 04:05 PM   #7 (permalink)
daveS53's Avatar
I did a little more research at the LS1 tech website and did verify that the GM ECU puts out -12V or "ground" signals to engage the fan relays.
Connecting the blue wire from the VA trinary switch to the 86 terminals on the fan relays should turn both fans on, when the condenser pressure gets to 254 psi.
I would be curious to know if these relays are mounted in a fuse/relay panel. The fans must be fused somewhere.
Old 03-18-2017, 04:33 PM   #8 (permalink)
daveS53's Avatar
All I can tell you is I have one and it works fine, operating a standard relay.
A modern AC system uses a pressure transducer with a 0-5V output that the ECU interprets.
http://www.ls2.com/boggs/dtcs/DTC%20P0530.htm
Old 03-18-2017, 08:03 PM   #9 (permalink)
Thanks Dave, that's very helpful. Both relay switches are separate from the fuse box and have the wires going to each relay in a loom. There is a pink wire that goes to each relay so that may be what links the two . I don't see a fuse associated with the relays.
Old 03-18-2017, 09:46 PM   #10 (permalink)
daveS53's Avatar
It's the red wires to the #30 terminals that should be fused. The relays just transfer the +12 volts to the #87, then the red/black should go to the fans.
Old 03-20-2017, 02:00 PM   #11 (permalink)
Shane's Avatar
First relay:
30--Red
87--Red/Blk
85--Pink
86--Grn
Second relay:
GM generally uses pink for ign+....so that make sense that they are supplying ignition power to pin 85 on both relays. Here is the problem....if you hook the VA switch to BOTH of those relays at pin 86 to ground them, the ECU will no longer be able to control the fans independently. Whenever it switches one relay on, the other will automatically come on since you just linked the two relays together with the blue VA switch wire.
If the ECU controls both fans independently, then in that case, you'll either give up that functionality.....or you'll have to use the blue VA trinary switch wires to trigger two separate relays that supply power to the two separate fans......in other words, set up an entirely separate control circuit to power the fans independently of the ECU and the ECU-controlled fan relays.
Link to Custom GTM Products on this Forum:
Shane is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 02:31 PM   #12 (permalink)
Shane,
Would that be a significant issue if independent fan function was lost? It seems you would want them both to go on if cooling is needed.
Keith
Old 03-20-2017, 03:31 PM   #13 (permalink)
daveS53's Avatar
Good info from Shane. I was afraid that was the case - two fans controlled independently. That really complicates things.
That makes me think that the folks at SMC really don't understand the product that they are selling. They should have known that connecting a wire from the trinary switch to both fan relays would make both fans run at the same time. You may need to find out who really makes the wiring harness and contact them for better info on making the harness AC compatible. There are also issues with controls to shut the compressor off at WOT or other high rpm conditions. I have none of that with my crate engine control from GM, so I just have to turn the A/C off if I want to mash the throttle.
There's also an issue with the type of compressor you're using. A VA system would use a Sanden style compressor with fixed displacement, but a modern GM system uses a variable displacement compressor that is not compatible with the expansion valve in the the VA system. Mixing the two is apparently not wise.
Secret to running LS1 compressor in expansion valve'd car?? - LS1TECH
How to wire AC Pressure Sensor without ECM control?
Vintage air non-pcm hook up
Old 03-20-2017, 05:16 PM   #14 (permalink)
Shane,
Could I use one independent relay near the fans to control both fans or would I need two separate relays?
Keith
Old 03-21-2017, 01:47 AM   #15 (permalink)
DIY
DIY's Avatar
kEITH,
I have a basic diagram on how I hooked up the VA system with an LS7 and stand alone harness. It might help give you a few ideas but may not be specific for your issue. The fans have there own set of relays run from the ECU. There are some basic notes in terms of the temp sensor 30118 wire(s) and I tried to color code to the extent I could. The fans work fine but I have yet to test the AC. I spent alot of time going over the wiring and I might need a tweak or two but it's pretty close. I added a third relay to take the signal from the Trinary and to power up the two fan relays. As I said...a few ideas to look at that may get you a little further.
The page is at: DOCUMENTS AND SCHEMATICS
DIY is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 01:08 PM   #16 (permalink)
Shane's Avatar
Shane,
Keith
If you want both fans to come on with the VA trinary switch, then you would need 2 separate relays....one for each fan. If you just used one relay to power both fans, then you have to link them together.....which would do the same thing as linking the grounds together back at the fan relays that the ECU controls....the ECU would no longer be able to control the fans independently.
Old 03-22-2017, 02:18 AM   #17 (permalink)
DIY
DIY's Avatar
In the diagram I use two relays to control the fans. They are tripped by the ECU. I use a third relay which is powered by the Trinary at 254 psi. When the third relay activates it supplies power to the ECU wire which has a diode to prevent power in reverse to the ECU. The fans react as if the ECU is supplying the signal when actually the Trinary is. That's the idea anyway. Similar to what Shane is saying in terms of relays. My concern was obviously getting the Trinary to have priority at high pressure and getting a signal to both fan relays simultaneously. Feed to the relay from the Trinary goes to relay terminal 86 to ground (85) supplying power tapped from 12v at terminal 30 and sending out via 87 (green). That green wire goes back to the ECU wire feeding the fan relays. For a reason I forgot but will revisit later is my reasoning for tapping the temp sensor wire (30118) into the same circuit. From what it appears (in general) the ECU wire can receive any 12v switched input to activate the fans. Since that wire is switched in the fuse box, if it's not on, I don't think back feed is an issue anyway. I simply turn it on via another switch whether the Trinary or something else attempting to get the fans on.
Old 03-22-2017, 01:03 PM   #18 (permalink)
daveS53's Avatar
I'm curious if the two fans are really controlled separately by the SMC harness and if so, why? The only reason I can think of is to have a staggered start, to reduce the amperage spike that would occur if both fans were turned on at the same time.
I also believe I see an error in the wiring diagram. The relay controlled by the trinary switch is grounded at 85 and the blue wire from the trinary switch that is also a ground, is connected to 86. That would not actuate the relay. One of those terminals needs a +12V connection.
Old 03-22-2017, 04:37 PM   #19 (permalink)
ARROWSTEEL's Avatar
If I remember correctly, the FFR manual was wrong and the fans must be grounded and they run together ether at low or high speed. I think I posted something about this during my first build.
Robert GTM #407 & 427
Ya, but it's only an 1/8 inch off!
What if I put a rope around your neck and your feet are only an 1/8 inch off the ground?
ARROWSTEEL is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 02:54 PM   #20 (permalink)
Thanks for the help guys. I think I'll go with the two separate relays option for the two fans. Just a couple of questions:
Will there be any adverse affects to the ECU fan relays or ECU if the fans are already on due to engine temp calling for it, and the separate relays for the A/C switches on the fans, going to the same connection to the fans, which are already running? Would this overload anything?
Also wondering, if the ECU fan relays are off, and the A/C relays turn the fans on, will there be any problems with current going through the connection at the fans and back up to the ECU fan relays? Would that harm the relays?
Also wanted to make sure I could use the same power wire from the battery and split to the two new fan relays rather than two separate fuse/breaker connections.
Thanks for the help, sorry for the novice questions, this is new to me, I really appreciate it.
Keith
Old 03-23-2017, 11:27 PM   #21 (permalink)
daveS53's Avatar
If you know where the +12V wire from the battery is (it must be fused or have a breaker), then it makes more sense to not disturb the signal wires from the ECU. There is nothing gained by doing that. A single fan power supply wire would have to be large (6-8 gage) and fused at 60-70 amps to operate both fans. Two separate wires would be 12 gage and each usually fused at 30A.
https://www.wirebarn.com/Wire-Calculator-_ep_41.html
The trinary switch can only operate both fans at the same time. Using the same power source for a second pair of relays, all you have to do is route the +12V power to terminal 30 and 86 of each relay, connect the +12V wire from each fan to the 87 terminal of each relay and connect the blue wire from the trinary switch to both of the 85 terminals. Then the fans will both come on when the pressure reaches 254 psi in the condenser. There will be no chance of any feedback to the ECU.
This is essentially how I wired my single fan. The only difference is I had an unused fan relay in my second fuse box, so I used it as the second power feed to the fans.
The option to connect the trinary switch signal to the ECU signal wires (all -12V) would make both fans come on at the same time, regardless of where the signal came from, but it does NOT require a second pair of relays. That's why I suggest finding out if the fans are really ever started at different times and if so why? The ECU would then have some sort of logic for only turning on one fan. Normally, two fans are used due to the short, but wide radiator shape. They're required to get good air flow through the entire radiator. I can see no reason to run just one. There is also only one temperature sensor in the engine's cylinder head that sends a varying voltage to the ECU.
The ECU should have its own solid state internal relay outputs that would not be affected by other -12V signals, but I would want assurance from someone who KNOWS that there will be no problem before trying that approach. That's the reason I chose not to do it.
Old 03-24-2017, 02:37 PM   #22 (permalink)
Thanks so much for the help Dave, I really appreciate it! The website with the recommended wire gauges will be very useful as well.
Insurance
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
Wow, not a single post...
06-16-2017 01:50 PM
by ROB J
Last post by stevo7896
Today 08:14 AM
21 Replies, 547 Views
4x4 Headers 302
Today 12:02 AM
Last post by Butch B
Today 05:12 AM
1 Replies, 63 Views
Lexan Windshield...Pros...
09-27-2016 06:45 PM
by dale
Today 05:08 AM
22 Replies, 1,011 Views
PS Reservoir Location
06-24-2017 01:34 AM
by jeepurz
Last post by jeepurz
Today 03:40 AM
6 Replies, 161 Views
Cobra Heat Switch Wiring
06-24-2017 04:00 AM
Last post by edwardb
Today 03:29 AM
3 Replies, 163 Views
Future selling prices on... ( 1 2 3 )
05-18-2017 10:42 AM
Last post by JoeE
Today 03:11 AM
61 Replies, 3,595 Views
Question on '69 Mustang
06-24-2017 03:28 PM
by aks801
Last post by Alan_C
Today 03:04 AM
7 Replies, 194 Views
Electronic Stability...
06-23-2017 07:25 PM
Last post by Alan_C
Today 02:38 AM
14 Replies, 368 Views
Fan relay wiring...
Today 02:32 AM
by jeepurz
Today 02:32 AM
0 Replies, 36 Views
Engine carnage Blown...
06-24-2017 08:52 PM
by JoeE
Last post by JoeE
Today 01:25 AM
8 Replies, 414 Views
Anyone using FAST...
07-10-2010 04:18 AM
by jvikla
Last post by Big-Foot
Today 12:01 AM
20 Replies, 32,680 Views
4x4 Headers 302
Today 12:01 AM
Last post by WAYNES WORLD
Today 12:01 AM
0 Replies, 42 Views
Any Roadsters Near North...
06-22-2017 09:30 PM
by B Fry
Yesterday 11:06 PM
4 Replies, 97 Views
Is it me, or is life...
06-22-2017 03:55 PM
by ROB J
Yesterday 11:02 PM
12 Replies, 319 Views
Selling Dale's MKIV...
Yesterday 10:59 PM
by dale
Last post by dale
Yesterday 10:59 PM
0 Replies, 124 Views
How fast is a bullet...
06-22-2017 03:54 PM
by USMC
Yesterday 10:53 PM
12 Replies, 482 Views
Sill covers
Yesterday 09:32 PM
Last post by John Dol
Yesterday 09:34 PM
1 Replies, 61 Views
#1001 Build Thread
06-02-2017 07:47 PM
by fostia
Last post by fostia
Yesterday 09:18 PM
12 Replies, 420 Views
Are the Casey Design...
Yesterday 01:06 AM
Last post by Blown 5.0
Yesterday 09:11 PM
1 Replies, 188 Views
How to fix my Turn...
06-23-2017 04:23 PM
by Butch B
Last post by Avalanche325
Yesterday 08:51 PM
4 Replies, 258 Views
Google
Roadster Forum
4.6L Roadsters
Big Block Roadsters
Non-Ford Powered Roadsters
GTM Forum
GTM Classifieds
GTM FAQ
'33 Hot Rod Forum
Hot Rod Classifieds
Challenge Cars
Road Racing
Autocross / Pro Solo
Drag Racing
Free Photo Hosting
Tires / Wheels
Tops & Tonneaus
Upholstery
Gallery
Audio / Electronics
Car Care
Insurance / Registration
Brakes / Suspension
Ford Big Block Tech
Ford Small Block Tech
Forced Induction / NOS
Fuel Injection Tech
National Events
Southwest
Northwest
NorCal
SoCal
Southcentral
Midwest
Southeast
Northeast
Canada
Off Topic Discussions
Other Car Discussions
Smyth Performance G3F
Parts For Sale / Wanted
Donor Cars For Sale / Wanted
FFCars.com News
Forum Help / Test
