The lines just behind the front and rear wheels are due to a break in air flow due to the wheel openings and the turbulence created by the rotating wheels at high speed. to lessen these two locations you would have to close up the opening between the tire/wheel and body opening which would increase the chance of wheel rub, also wuold need a wheel that disturbs less air ( flat on face like a salflats speed car ) not very appealing or practical. The area just behind the door is because of the side scoops built into the quarter panels, the opening into the scoop is not as large as the begining of the scoop. The scoop closes up from the bottom and at high speeds draws more air than can enter the scoop opening and creates a small venture effect. The size and locations of the dust markings are at locations and sizes that I would not worry about them unless you plan on competeing professionally, there is not enough of drag created by these markins two justify the expense, Besides you have a great looking car that needs nothing to change the looks at all.
