Originally Posted by golfer895
how hard is this to set up?
The CMS G50 side shifter? I would describe it as the most un-fun set-up I've worked on so far. Both cables at the transaxle end up in the worst possible position for getting them routed, adjusted and tightened. I also felt that it was also the worst shifter feel inside the car. I did not install the CMS shifter set-up......used the Brandwood Cableshift box/cables, but the trans had the side-shifter set-up on it. No offense to CMS as they build some awesome transaxles, but for cable shifting, I see zero advantages to the side-shifter set-up and about 100 disadvantages. It may work out better in a different vehicle, but for the GTM, it's just a real PITA.
