1200 HP GTM : Nelson Racing TT mirror turbos - FFCars.com : Factory Five Racing Discussion Forum
Old 08-04-2012, 05:43 AM   #1 (permalink)
Hand Jabba the Hut
Nemo's Avatar
Thought this was pretty sweet to say the least.
http://www.youtube.com/watch?v=kMWpe...e_gdata_player
Sent from my Autoguide iPad app
Nemo is offline   Reply With Quote
Old 08-04-2012, 11:25 AM   #2 (permalink)
MJN
MJN's Avatar
Like the man said, 10 pounds of stuff in a 1 pound bag. Bit of an understatement. Very impressive and I'm sure that if you have to ask how much that you can't afford it.
Mike....
Old 08-04-2012, 02:13 PM   #3 (permalink)
fuzzyjk's Avatar
That's what 285k will buy you.
fuzzyjk is online now   Reply With Quote
Old 08-04-2012, 07:10 PM   #4 (permalink)
North Florida
iron.man's Avatar
Air / water innercoolers in an engine compartment with no air flow where the motor is designed to run at 210 degrees with the stock thermostat and where the turbos AND HEADERS are literally less then 12 in away are NEVER going to help with those intake temperatures... and Id be willing to bet the water pump MELTS even if circulated on the cool side ... how would I know... I just finished dealing with all of that.
and 4 extra head bolts wont make a difference when it detonates at 16 psi .
But Im sure its just me being negative... wow at the time/money spent in that fabrication, hope whoever paid for that gets what the wanted !
iron.man is offline   Reply With Quote
Old 08-04-2012, 11:30 PM   #5 (permalink)
something tells me NRE knows wtf they are doing! lol
TiagoTT is offline   Reply With Quote
Old 08-05-2012, 06:17 PM   #6 (permalink)
flotowngtm's Avatar
Anyone know what type of trans that is that's about to get destroyed?
flotowngtm is offline   Reply With Quote
Old 08-05-2012, 07:39 PM   #7 (permalink)
North Florida
iron.man's Avatar
Samething was said about Obama and look how that turned out.
Old 08-05-2012, 10:07 PM   #8 (permalink)
smiling
you made me smile for the day iron man,
thanks
dave
kitcarbuilder is offline   Reply With Quote
Old 08-05-2012, 10:24 PM   #9 (permalink)
Iron man, most of the guys that run the water/air intercoolers on their 1000+ hp turbo street rides just turn on the pump (using Hobbs switch or similiar) when they are going to get on it and then turn it back off. This seems to work pretty good for short bursts or a 1/4 mile pass (if you let it cool down between passes). No doubt if the GTM in question was endurance racing under repeated boost things would quickly become heat soaked. Cheers.
FFR 4031K, twin-turbo dart block 331, AOD, 144.91 mph in the 1/4 mile http://www.youtube.com/watch?v=AQtmrxaRVTg
Thomas W is offline   Reply With Quote
Old 08-06-2012, 01:44 AM   #10 (permalink)
LMAO!!! thats funny right there
but NRE has proven themselves, over and over again.
Old 08-06-2012, 05:06 PM   #11 (permalink)
North Florida
iron.man's Avatar
Thank you Thomas for you input and education. Your words are inspirational and I hope for that guys sake you have the experience to know what your "typing" about. I personally have owned a lightning truck now for over 10 years.... started off as a stock blower motor and now is all aftermarket stuff. It has a factory installed intercooler with a ford circulating water pump that runs when the key is turned on. When its working, the overflow reservoir shows alot of movement and when it doesnt work the water is literally still.
I was riding down the road in my truck at about the 5 year mark, and all of a sudden I had ALOT of PING that started around 6 psi of boost. That is really odd since I had been running 12 psi for a year and never had an issue. After two tanks of gas, I still couldnt push the throttle past 50 percent because it would studder really bad. I hooked up my predator and read my intake temps ... before the blower was the same that my little dash thermometer read... whatever the outside air was, thats almost always what it read plus a degree to two. The manifold temp sensor ( after the intercooler ) was hitting 280-320 degrees at idle and would cool down to 200 degrees under boost ... did you read what I said ?? ... it would COOL down under boost !! .. So I knew something wasnt right. Popped the top on the reservoir and I didnt see any movement. The reservoir was full, but the electric pump was broken. Without circulation, the innercooler will pick up heat from EVERYTHING thats anywhere near it !!! The inside of it isnt the only thing picking up the heat... ITS ALL ALUMINUM... so its gonna heat soak anything in the vicinity of itself. You have to keep the pump on all the time... just turning it on every now and then would take 10-15 minutes to get the extra heat out even if its only at cruising speed. I hooked up a good pump to my sandwich intercooler and it took 20 minutes for the temp guage to stop moving, but its underneath my blower so an external one like that one should work a little quicker.... if it wasnt sitting on the manifold and the turbo which will make may more heat than an engine block. I have been there man, I have tried whats in that picture and I was only running a single turbo on mine which would make way less heat. I have turned exhaust wrap into ceramic glass before and completely melted exhaust pipes through so I dont think your explaination of it works just because it looks nice is gonna make sense to me.... cause it wont !
Google
