speedo help please - FFCars.com : Factory Five Racing Discussion Forum
Old 06-29-2012, 03:42 PM   #1 (permalink)
whosnext's Avatar
speedo help please
I bought my car as a roller and the wiring was already done, I’m having a problem getting my speedo to work? I found a diagram of the way the previous owner hooked it up, can someone confirm this is the correct way ? I did do a search and read allot about the sensor not being close enough to the wheel but I don’t think this is the case as it’s about 1mm away from it..any info would be great.
whosnext is offline   Reply With Quote
Old 06-29-2012, 05:22 PM   #2 (permalink)
PSB
PSB's Avatar
What brand of speedometer? Autometer recommends wiring directly to the VSS, not through the computer. That's how I've got mine hooked up.
http://www.autometer.com/productPDF/1164.pdf
Pete
Hunter Kit Cars #37
Build Album: http://www.photobucket.com/Hunter37
PSB is offline   Reply With Quote
Old 06-29-2012, 05:26 PM   #3 (permalink)
whosnext's Avatar
Pete
it is a autometer (gen 1)do i ground 1 wire and and send other to signal termanal on gauge?
Old 06-29-2012, 06:59 PM   #4 (permalink)
eseethal's Avatar
You should run the VSS through the PCM, it needs the speed usignal, otherwise you will experience stalls (I went through this), I have mine wired like in your picture (not sure about the pins of the ECU). I used the stock ABS sensor of the corvette, the PCM needs to be calibrated for this to get the speed reading right.
That worked perfectly for me!
Eugen
GTM #006 (early beta), red
On the road in Austria/Europe
Stock LS-1 with Kooks / G50/01
C6 ZO6 brakes, Forgestar wheels from FFR
eseethal is offline   Reply With Quote
Old 06-29-2012, 07:21 PM   #5 (permalink)
whosnext's Avatar
Eugen
i am experiencing stalls at low rpm's down shifting from 2nd to 1st sometimes...who calibrates pcm's?
Old 06-30-2012, 08:08 AM   #6 (permalink)
eseethal's Avatar
yes, that is a typical symptom, the PCM needs the speed signal! The PCM can be flashed with HP tuners or similar software, or from any tuning company. I suspect, you do not get any VSS reading at all. If you do not plan to use an anti lock brake, use the right rear wheel sensor.
Good luck......Eugen
Old 06-30-2012, 04:11 PM   #7 (permalink)
whosnext's Avatar
thank you for your help....i have a buddy that has a handheld T-1000 DIABLOSPORT TRINITY PROGRAMMER TUNER....could this be done on this?
Old 07-01-2012, 08:15 AM   #8 (permalink)
eseethal's Avatar
It could be that you can adjust that with this tool - but I am not sure. The homepage says, you can calibrate tire sizes, so this could be sufficient. You can calibrate the speedo on its own, so the VSS for the PCM does not have to be precise. Only if you want to log the correct speed. In the first step I would try to get any VSS to the PCM and from there to the speedo and not worry about the calibration. If the PCM detects the movement of the car, it will at least not stall any more.
Eugen
Google
