Programmable fuel gauge - FFCars.com : Factory Five Racing Discussion Forum
Old 10-27-2010, 09:27 PM   #1 (permalink)
For those using the Autometer 4310 programmable fuel gauge, does it read accurately with the Corvette senders? Each sender is 40 (E) to 250 (F) ohms. The 4310 can be programmed for one sender for these limits, or using both senders in parallel, 20-125 ohms. I'm considering switching to this gauge and would appreciate some feedback.
BigBlue is offline   Reply With Quote
Old 10-27-2010, 10:44 PM   #2 (permalink)
I don't have feedback on this gauge, but if you have a crossover, I would use just the sender in the passenger side tank. That's what I do (I have the Nordskog gauges) and it works very well.
GTM Chassis #26
Stock LS-6. PHII G50-50, Shane's Louvers, Nordskog Dash, Shaved Door Handles,
Rear View Camera, David Borden's Aluminum Dash Cover for Nordskog,
Rollbar Covers -- http://quickracingproducts.com/html/interior.html
Dash
GTM Build Pics: http://www.gtmbuild.com/galleries/mikes_build/index.htm
mdowns is offline   Reply With Quote
Old 10-27-2010, 11:30 PM   #3 (permalink)
Administrator
David Borden's Avatar
I used it and it worked perfectly...
David
David Borden is offline   Reply With Quote
Old 10-28-2010, 04:43 PM   #4 (permalink)
Thanks guys, I've ordered it.
Old 10-28-2010, 05:04 PM   #5 (permalink)
ArtGirl's Avatar
I feel like I've missed something. Absent the crossover, what sort of configuration would allow you to access fuel from both tanks?
ArtGirl is offline   Reply With Quote
Old 10-28-2010, 06:18 PM   #6 (permalink)
A pump in both tanks where you control which pump is running from the cockpit. Then use sending units in both tanks separately so that only the tank with the currently running pump is sending to the gauge.
GTM Chassis #26
Dash
Old 10-28-2010, 06:23 PM   #7 (permalink)
www.myraceshop.com
Don't forget, you also have to split the return line if you leave the tanks seperate.
Old 09-17-2012, 07:19 PM   #8 (permalink)
Richard Oben's Avatar
Sorry for the thread resurrection but I just want to get this clear in my brain. Do I just disconnect the driver tank and use the sender from the pass tank to the programmable gauge? Like I said with the sealing of the tanks I only want to do this once.
I will do all the calibration off of the car if I can with the sender some wires and a battery. The whole programing thing seems a little odd but I am sick of the car without an accurate gauge.
My other question is since the tanks are not linear shaped is the gauge linear? For example does it go from full to half really fast and then slow down to empty?
Sorry for all the questions but it has been I while since I messed with the car. Richard.
Old 09-18-2012, 07:12 PM   #9 (permalink)
If you have the crossover line you can use either sender or both in parallel. In my case I have the crossover and use the passenger side sender by itself. I have a selector switch to connect to the other sender but this is not required with the crossover and I never use it. I programmed the gauge out of the car using the 10-turn pot. The senders seem very linear, when I add a certain number of gallons the gauge reflects this accurately over the whole range. I am very happy with it.
Old 09-18-2012, 10:35 PM   #10 (permalink)
Great, I will not use the other sender and just remove the other tank from the gauge system. Richard.
Google
