LED Brake & Signal Lights - FFCars.com : Factory Five Racing Discussion Forum
LinkBack Thread Tools
Old 04-02-2009, 03:11 PM   #1 (permalink)
jmciver's Avatar
Have any of you guys building GTMs considered using LED rear lights? I don't know the dimensions of the GTM rear lights, but they don't look like anything really special/custom. 4" diameter universal tail lights (LED or traditional) seem rather common and I am assuming the GTM rear lights are 4" diameter as well.
I started thinking about this since I happened to find some that have integrated backup lights, making for a clean install. What do you think?
jmciver is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 05:36 PM   #2 (permalink)
They look great, but haven't seen them on a car. We just need a brave soul to take the leap!
GeeTM is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 05:45 PM   #3 (permalink)
GTM Newb
NAVY08's Avatar
Send a message via AIM to NAVY08
Photoshop? I would love an option for the tailights on the GTM, they are my least favorite item on the car.
NAVY08 is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 05:58 PM   #4 (permalink)
jmciver's Avatar
Here is something similar I found on an Ultima GTR.
Old 04-02-2009, 06:09 PM   #5 (permalink)
jhilb's Avatar
I've looked everywhere and couldn't find a set that fit.
I've seen these, but didn't have a part number on them? What is the part number? I am most interested in a taillight, LED or otherwise, that is physically shorter than the 4.5" of the kit provided ones.
jhilb is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 06:34 PM   #6 (permalink)
Assuming that they are the same diameter as the original tail lights, and that you don't mind looking at my rear cut-out and tailpipe ideas, you end up with something like this.
MarkH is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 07:08 PM   #7 (permalink)
New
definately would look much better with a blackout lense cover.
Don't know crap but like to learn everything
Turbohips is offline   Reply With Quote Quick reply to this message
Old 04-02-2009, 08:07 PM   #8 (permalink)
This version is probably more realistic.
Old 04-02-2009, 08:49 PM   #9 (permalink)
jmciver's Avatar
That looks pretty good. As far as size goes, I was hoping someone in a build could confirm the size of the GTM tail lights.
For jhilb, they are made by a company called Maxxima. Just do a search for Maxxima LED and you will find venders that sell them. I have seen them priced between $30-$50.
I found some dimensions info on another site:
3 Hole Flange Mount 3/16" dia. Hole
Bolt Pattern 5" dia.
Here is a diagram (hard to read though)....
Old 04-02-2009, 09:28 PM   #10 (permalink)
jhilb's Avatar
Thanks. I will get the exact taillamp measuresments when I get home.
MarkH. I have the tail pipes like your thinking of doing, I will get a shot for you.
Old 04-02-2009, 10:31 PM   #11 (permalink)
Cool. It makes good aesthetic sense to me to repeat the double horizontally grouped circles of the taillights in the tailpipes. What diameter exhaust tips did you end up using?
Sorry for the thread hijack.
Old 04-03-2009, 03:17 AM   #12 (permalink)
jhilb's Avatar
Tips are just shy of 3", they measure 2 7/8". I will get a better straight-on shot for you over the weekend.
JMC.. here are the measurements on the tail lamps...
I measured 4.75" wide, Hella lists them as 5" wide.
2.5" deep measured from the lip where it would sit against the body, to the back. It does not include the 0.75" of lens
Old 04-03-2009, 03:39 AM   #13 (permalink)
Shane's Avatar
Hella makes these. I've used them before but don't have dimensions for them.
http://www.rallylights.com/detail.aspx?ID=1236
Link to Custom GTM Products on this Forum:
Shane is online now   Reply With Quote Quick reply to this message
Old 04-03-2009, 04:20 AM   #14 (permalink)
jhilb's Avatar
Unfortunately the Hella LED versions are only 4".
I've not found any 5" LED lights. I was considering making an LED plate and using that inside the same housing, but shortening the housing. Problem is, the inside of that housing is pretty complicated.
Old 04-03-2009, 04:24 AM   #15 (permalink)
jmciver's Avatar
Hmmm.... Good find, it seems like that company also sells the tail lights that are used on the GTM. Based on the dimensions provided by this company and the ones for the LEDs posted above, it looks like the LEDs posted above should fit (both have an overall diameter of approx 5").
Old 04-03-2009, 01:38 PM   #16 (permalink)
jhilb's Avatar
We are off somewhere.
Those lights posted directly above are not the GTM lights. They are 4" (98 mm or 3.85") LEDs made by the same company (Hella).
These are the GTM lights...
http://www.rallylights.com/detail.aspx?ID=2333
They are 5" diameter.
Unless your looking to use tail lamps smaller than originally provided, the Maxxims will not work.
Old 04-03-2009, 02:17 PM   #17 (permalink)
jmciver's Avatar
Oh, I knew the lights that Shane originally posted were not the GTM lights. I went looking around the same website and found what looked to be the GTM lights (I should have made that more clear). The reason I think the LEDs above may fit is that the LEDs I posted above, according to some info I read about them, use a standard 3-hole, 5" diameter flange. If I understand it correctly, the outer ring of white LEDs, which are part of the flange, bring the overall diameter of the LED lights to 5". If that is true, then there is a good possibility that the LED lights will fit with minimal "work".
Of course, exact measurements are necessary to verify if these LEDs will fit. But the initial info seems to look promising.
Old 04-03-2009, 04:19 PM   #18 (permalink)
GTM Newb
NAVY08's Avatar
Awesome, thats pretty exciting, i like these lights a lot
Old 04-03-2009, 04:24 PM   #19 (permalink)
That is also the way I'm reading the Maxxima product info. It appears that the central element is their basic 4" LED cluster, while the white LED flange is the same as the no-white-LED flange in this product. That would mean that the overall diameter is 5.5". If anything, the Maxxima products are too big. The current GTM taillights are listed as 125mm in the product description, but as 122.5mm in the associated diagram. At 5.5", the Maxxima taillights are 139.7mm -- which almost certainly means that they will not fit in the existing taillight recesses in the GTM bodywork.
If you were to do the body work needed to make them fit, you'd end up with something like this:
Old 04-03-2009, 06:02 PM   #20 (permalink)
jmciver's Avatar
Nothing that a little Dremel tool action and Bondo action can't make work, just not by me . I think they do look nice though and will be something I will definitely consider when the time comes.
Old 04-03-2009, 06:10 PM   #21 (permalink)
I just tried to purchase a set, but it said they were out of stock.
tgroah5rvn is offline   Reply With Quote Quick reply to this message
Old 04-03-2009, 10:52 PM   #22 (permalink)
jhilb's Avatar
Hmm, lemme go look, I read it incorrectly then.
I cannot read that diagram but it looks like it says 5" ?
So yeah, I guess they will fit.
Are these them?
http://cgi.ebay.com/ebaymotors/4-Rou...3A1|240%3A1318
They look huge.
Old 04-03-2009, 11:25 PM   #23 (permalink)
jmciver's Avatar
Are these them?
They look huge.
They might be. But then the dimensions don't seem to match the other data we have found for them either. But they do look huge though....
Old 04-04-2009, 01:19 AM   #24 (permalink)
I've done some measurements of the available photos (which, of course, does not give exact dimensional results), and I'm pretty confident that when these are referred to as 4" lights, what that means is that they are designed to be installed in a 4" hole. The back of the center portion of the light installs through the 4" hole, while the white LED portion is a flange that surface mounts. If the flange bolts are on a 5" circle, then the overall diameter is somewhere between 5.5" and 6".
Old 04-04-2009, 04:00 AM   #25 (permalink)
jhilb's Avatar
Ah, that makes sense now. I think these are for tractor trailers.
Old 04-04-2009, 11:31 AM   #26 (permalink)
jmciver's Avatar
Yes, they are truck lights. Since the GTM lights are round, it seems like these type of LED lights are pretty much the only show in town, unless you want to fabricate your own.
Too bad these look like they won't work out without some decent amount of body work (but maybe somebody will still try). The integrated reverse lights is pretty key for a simple GTM solution but is also a PITA .
Old 08-31-2009, 02:11 AM   #27 (permalink)
jmciver's Avatar
I thought I would bring this thread back to life since I stumbled across some LED tail lights that might actually fit this time. I found these being sold by a UK company here: www.cbsonline.co.uk They are not that cheap, at about $300 a pair when you take the currency conversion into account, but I think they look better than the current GTM tail/turn/reverse lights.
Both models have an overall diameter of 122mm (the GTM lights made by Hella have an overall diameter of 122.5mm) so adapting them to fit should not be that difficult. The one on the right (with the oval center) is available with the center as white (for reverse) or amber (for turn). I believe the one on the left has the same options but it was not specifically mentioned in the description on the site.
So what do you think?
File Type: jpg ferrari_led_rear_light_off[ekm]308x300[ekm].jpg (19.0 KB, 38 views)
Old 11-08-2009, 07:51 PM   #28 (permalink)
New LED Tail Lights
I'm reviving the thread again. I have spent many long hours looking for the right tail lights. I was going to go with the Nissan GT-R LED tail lights, but they are near impossible to get and very pricey ($400 each side), not to mention the body work to make them look right. In the end I have found an OEM LED light that fits perfectly. The lenses stick out a little (kinda like a Ferrari), but they also have turn indicators on the side of the lens, so I like the look. Let's see who can tell us what they came off of?
I connected them up to my Optima and they are extremely bright.
565HP LS7, G50-52 LSD, Non-Donor build, Z06 Brakes, Kooks, ISIS.
My Mustang Build site:
LS7-GTM is online now   Reply With Quote Quick reply to this message
Old 11-09-2009, 02:17 AM   #29 (permalink)
06+ Euro spec Lotus elise outer, and US inner.
I like them for the sole fact that they have no mounting hardware visable from the outside... I personally would sink them flush to the body, but that's just me.
However what scares me is the cost... Looks like about $400 for the setup (from a web search, please correct me if I'm wrong as that may be per side) Also I read conflicting reports... someone said that there may need to be a balast module.. but I don't see the need for just an LED setup.
temperacerguy is offline   Reply With Quote Quick reply to this message
Old 11-09-2009, 04:41 AM   #30 (permalink)
jhilb's Avatar
Agreed, recess them. They look a bit bulky for me.
How much do they 'protrude' into the tail section. I mean, how deep are they on the inner side of the body? The original supplied Hellas are like 4.5" right?
Insurance
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
WTB MK III Seats
Today 01:12 PM
Last post by Cobra MD
Today 01:12 PM
0 Replies, 2 Views
06 Ford GT 293.6
Yesterday 09:41 PM
by CraigS
Last post by jimgood
Today 01:04 PM
3 Replies, 94 Views
Mickey Thompson Street...
Yesterday 07:14 PM
Last post by Real time recon
Today 12:05 PM
7 Replies, 179 Views
Cooper Cobras
Yesterday 11:14 PM
by Mike D
Last post by j.miller
Today 08:10 AM
4 Replies, 206 Views
Radiator opening/hood...
Yesterday 04:10 PM
Last post by Blown 5.0
Today 07:57 AM
6 Replies, 185 Views
Another unnecessary...
Today 03:27 AM
by jeepurz
Last post by CRZN 427
Today 07:02 AM
1 Replies, 140 Views
Coyote first start - and...
Today 04:25 AM
Last post by 2bking
Today 05:30 AM
1 Replies, 71 Views
Fraser D Track... ( 1 2 )
06-06-2014 10:11 PM
Last post by ARROWSTEEL
Today 05:12 AM
37 Replies, 2,831 Views
Washing a Roadster??
03-25-2017 04:38 PM
Last post by stevo7896
Today 04:57 AM
27 Replies, 748 Views
New Builder - MK4...
Today 03:49 AM
Last post by manrigdude
Today 03:49 AM
0 Replies, 44 Views
Almost there!
Yesterday 08:46 PM
Last post by Driver_WT
Today 03:43 AM
5 Replies, 145 Views
Announcement - APE...
12-11-2016 06:58 PM
by Craig
Today 03:42 AM
20 Replies, 1,405 Views
Passenger ​Gas Tank...
Yesterday 02:48 AM
by jeepurz
Last post by jeepurz
Today 03:15 AM
7 Replies, 214 Views
Start VARA High Desert...
Today 02:54 AM
Last post by maui1972
Today 02:54 AM
0 Replies, 37 Views
The Official FFR Top Dog... ( 1 2 3 )
01-25-2015 09:36 AM
by jimgood
Today 02:51 AM
69 Replies, 4,257 Views
Hardtop replacement rear...
Yesterday 10:24 PM
Last post by Derald Rice
Today 02:49 AM
1 Replies, 90 Views
cars and coffee
Today 02:29 AM
by acmikee
Last post by acmikee
Today 02:29 AM
0 Replies, 39 Views
What did you do to your... ( 1 2 3 4 5 ... Last Page)
01-15-2012 04:39 PM
Last post by CanuckRacer
Today 02:18 AM
2 Replies, 143,949 Views
Paint Code for White...
Today 12:26 AM
Today 02:00 AM
2 Replies, 74 Views
High Res Pic of Lexus...
04-19-2016 10:46 PM
Last post by JKleiner
Today 01:46 AM
4 Replies, 677 Views
Google
Roadster Forum
4.6L Roadsters
Big Block Roadsters
Non-Ford Powered Roadsters
GTM Forum
GTM Classifieds
GTM FAQ
'33 Hot Rod Forum
Hot Rod Classifieds
Challenge Cars
Road Racing
Autocross / Pro Solo
Drag Racing
Free Photo Hosting
Tires / Wheels
Tops & Tonneaus
Upholstery
Gallery
Audio / Electronics
Car Care
Insurance / Registration
Brakes / Suspension
Ford Big Block Tech
Ford Small Block Tech
Forced Induction / NOS
Fuel Injection Tech
National Events
Southwest
Northwest
NorCal
SoCal
Southcentral
Midwest
Southeast
Northeast
Canada
Off Topic Discussions
Other Car Discussions
Smyth Performance G3F
Parts For Sale / Wanted
Donor Cars For Sale / Wanted
FFCars.com News
Forum Help / Test
