Power steering - FFCars.com : Factory Five Racing Discussion Forum
LinkBack Thread Tools
Old 10-27-2008, 08:20 PM   #1 (permalink)
samurai41's Avatar
Power steering
This was posted in a different thread,By Donnie B. I thought it should have it own.
JimO,
I was at FF5 in May and they had the power steering installed in the GTM. They will tell you how and what to buy if you want to do it. I believe the only thing that was not purchased off the shelf was the power steering hoses.
Don
samurai41 is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 09:23 PM   #2 (permalink)
spytech's Avatar
When I asked Jason about power steering he sent me this:
"Power steering is definitely something Id recommend its really nice. Just get a power rack for an 87-93 Mustang GT, and we have adapters available here for the steering shaft. Then youll just need an electric pump (unless youre not running AC) and have some lines made up."
Completed (for now): GTM #232 w/ Stroked LS2 408 making 624hp/572ft-lb, G50/52 trans, Kooks exhaust, Push-button start, RaceLogic Traction Control
Build Log:
Vids:
spytech is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 10:49 PM   #3 (permalink)
Administrator
David Borden's Avatar
I believe the pump they are using is the Subaru XT electric pump. I understand they are a bit pricey. Im still looking into making an adapter to run the stock C5 pump with a smaller pulley and changing the location of the pump. Its quite small, so theres a small chance it would work based on the short look I had.
David
Mk4 Build Thread:
GTM Project Build site:
David Borden is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 11:32 PM   #4 (permalink)
Send a message via AIM to Hayabusa02
Power Steering was surprising and well worth it. If I ever do antoher car I will definitely do it.
GTM#102
Katech LS2 478HP/461TQ, Kooks Exhaust, G50-20 Rebuilt & strengthend, Side Cable Shifter, Quaife LSD, Sachs Organic Clutch, Nordskog Instrument Cluster
Hayabusa02 is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 01:16 AM   #5 (permalink)
spytech's Avatar
David
Correct - Jason told me today that is what pump they used. He said he is going to research and see if there are any better solutions.
Did you end up changing over to power steering? I'd hate to waste the shiny new GTM steering rack and throw an old mustang rack in there.
Build Log:
Vids:
Old 12-21-2008, 08:18 PM   #6 (permalink)
GTM# 255
Power Steering Update
Does anyone have any updated information about power steering in the GTM
Scrivy is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 01:44 AM   #7 (permalink)
Ron565's Avatar
What year Subaru XT ? Price? Just the power streeing pump or does it come with the electric motor?
The mustang rack and pinion steering with the 15.0:1 Right?
What other stuff do you need?
Thanks for the info. Ron, Happy Holidays
GTM #66
LS3.2 525 HP
Custom G-50/01 LSD
New photo album
Ron565 is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 07:01 AM   #8 (permalink)
Aman's Avatar
Been posted here before but perhaps worthy of a repost.....
And this would allow you to maintain the nice GTM steering rack. I don't think the amount of assist is variable though...
http://www.unisteer.com/mm5/merchant...+ELECTRA+STEER
Aman is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 12:11 PM   #9 (permalink)
Owner of WGP
Send a message via AIM to Bullitt 2496
Has anyone successfully mounted one of these in a GTM? The space between the joints of the steering shaft are extremely tight...
Bullitt 2496 is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 12:25 PM   #10 (permalink)
Shane's Avatar
Looks like it would be VERY tight indeed. There's not enough room between the rack and flange bearing to put it, and putting it under the dash....I'm guessing would require some serious mods to the frame and pedal-box area to make it fit. Surely the brake light switch would have to be re-located so that bracket could be removed to make room also.
Link to Custom GTM Products on this Forum:
Shane is online now   Reply With Quote Quick reply to this message
Old 12-22-2008, 11:27 PM   #11 (permalink)
Administrator
you would first need to find a quicker rack. The problem with the existing rack isnt that its heavy, its actually quite light... but the steering is slowwww for the type of car. I wonder if you can find a similar rack with a quicker ratio. The rack is the same size as one in a late 80's early 90's mustang GT.
Im still going to look into mounting the stock PS pump on the front of the motor but wont be taking it apart until I go to add the crossover for the fuel tanks this winter. I would use the mustang rack if I can get it to work.
David
Mk4 Build Thread:
Old 12-23-2008, 12:50 AM   #12 (permalink)
Owner of WGP
I found a quick ratio power mustang rack and the Subaru Pump... im going to mount the pump to the frame above the cooling fans on the driver side... will post pictures when I get it mounted.
Old 12-23-2008, 12:13 PM   #13 (permalink)
Spotless
ahedmonds's Avatar
Electric PS Pump
1991 Toyota MR2 Spyder
P/N 44310-17011
$426 New from Toyota Dealer
Have not installed yet...didn't realize how little time I had until
attempting this build. Not in a hurry though.
Herb
Kit received 10/28/08, '99 Donor, '97 G50-20-1
Put spot remover on my dog, now he's gone!
ahedmonds is offline   Reply With Quote Quick reply to this message
Old 12-23-2008, 11:10 PM   #14 (permalink)
Aman's Avatar
the MR2 pump is likely the route I'll go aswell, with a DC motor modulating switch mounted inside to adjust the amount of assist. I've read that at full speed they can be quite loud.
Any sources on the quicker mustang racks?
Aman
Old 12-23-2008, 11:50 PM   #15 (permalink)
eeeny's Avatar
Kragen online has remanufactured MR2 pumps for $188 plus $50 core.
It comes with "lifetime warranty" whatever that means (probably means the warranty runs out when the pump dies!)
GTM #240, LS376, G50-05 w/OS Giken, Kooks
Kit arrived Nov 21 2008 (SOLD)
eeeny is offline   Reply With Quote Quick reply to this message
Old 12-23-2008, 11:50 PM   #16 (permalink)
Richard Oben's Avatar
The stock rack is a Mustang replacement at 15 to 1. The stock mustang power steering rack is advertised at 15 to 1 but in reality is more like 13.5 to one. It is pretty fast, in most cases people tend to reduce the pressure spring in the factory pump to reduce the assist. I have no problem with the manual rack. Cheers Richard.
Richard Oben FFR builder
Richard Oben is offline   Reply With Quote Quick reply to this message
Old 12-25-2008, 06:34 PM   #17 (permalink)
Ron565's Avatar
I found this
http://www.driveev.com/jeepev/convpgs/psteer.php
GTM #66
LS3.2 525 HP
Custom G-50/01 LSD
New photo album
Old 12-26-2008, 07:47 AM   #18 (permalink)
Ford Focus / Volvo S40 & V50
The Ford Focus 2004- up uses an electrical pump w/integrated tank I think. also the Volvo S40 and V50 from about the same years.
Swedish listings of used such pumps show prices around 2000 SEK = $250.
It's a pretty nice setup with the integrated reservoir, but it makes the unit tall...
Still waiting for my GTM to arrive, and I dont have measurements of the Focus pump so I have no idea if this is a possibility.
/Thomas
Tmzand is offline   Reply With Quote Quick reply to this message
Old 12-26-2008, 03:12 PM   #19 (permalink)
Administrator
/Thomas
Thats an interesting set of options... Most of what I have read about the focus has been good as far as handling and responsiveness, so maybe the pump might work. Anyone here have a focus, or work for a ford dealership to get an idea what this thing looks like?
Hopefully, it or the Volvo pump is self contained and doesnt rely on a computer to control it.
David
Mk4 Build Thread:
Old 12-26-2008, 03:37 PM   #20 (permalink)
Jack of all trades - expert at nothing
JayP's Avatar
nice options,
you guys are scary what you come up with!
Glad you're not terrorists...or are you just a sleeper cell?
The "last" Spyder picked up (for now).#0039GT. And a '70 Cougar 351C needing attention. In the mean time I'll run around in my Raptor.
JayP is offline   Reply With Quote Quick reply to this message
Old 12-26-2008, 08:19 PM   #21 (permalink)
Administrator
I found this post with some very specific details on the installing a MR2 electric pump. What I find interesting, is the pump has an adjuster that allows you to adjust the pump pressure to your rack/liking...
The install was done by a racer for a race car and it appears to work well for him and the pumps should be available since the MR2 was a fairly popular car. Cost should be around $150-200 for the pump.
http://www.honda-tech.com/showthread.php?t=2222562
If someone tries this, I could machine a custom bracket for the pump if folks were interested.
Heres a link for wiring the MR2 pump.
http://www.evalbum.com/tech/mr2_powersteering.html
David
Mk4 Build Thread:
Old 12-26-2008, 09:31 PM   #22 (permalink)
Aman's Avatar
That's the same thread I'd reviewed a little while ago, main complaint seems to be the noise and possibly the pump longevity considering it's always 'on'.
This is where a DC proportioning switch seems to make a lot of sense, rather than a 'bypass' adjustment for the amount of assist. Full assist in slow driving, minimal assist at speed, at the flip of a switch. I believe it's mentioned in that thread by a guy that installed it in his subaru impreza.
Of course then the solution isn't just install and forget about it, but I think that's ok.
Aman
Old 12-27-2008, 12:03 AM   #23 (permalink)
Mjollnir's Avatar
the MR2 pump is likely the route I'll go aswell, with a DC motor modulating switch mounted inside to adjust the amount of assist. I've read that at full speed they can be quite loud. Any sources on the quicker mustang racks?
Aman
Any info on the DC motor modulating switch??
Roger
GTM kit 233
Build site
Mjollnir is offline   Reply With Quote Quick reply to this message
Old 12-27-2008, 12:55 AM   #24 (permalink)
Aman's Avatar
Roger
Pretty sure it's just a potentiometer that uses pulse width modulation as the signal to the DC motor
http://cgi.ebay.com/DC-Motor-Speed-C...QQcmdZViewItem
Aman
Old 12-29-2008, 01:39 PM   #25 (permalink)
www.myraceshop.com
Sounds like this thing could be hooked up to a small electronic gizmo that would not only allow driver adjustability with a knob, but also programability for automatic adjustment as speed varies.
crash is online now   Reply With Quote Quick reply to this message
Old 12-29-2008, 04:45 PM   #26 (permalink)
Administrator
agreed... and Im also wondering if it would be possible to use the original PS ECU and tap into the LSx PCM to control the pressure. Based on the link I posted above, it appears to be fairly easy to wire if signals are compatible.
David
Mk4 Build Thread:
Old 12-29-2008, 08:15 PM   #27 (permalink)
JayP's Avatar
Dave,
Now you're getting real scary...
great idea.
Old 01-02-2009, 10:58 PM   #28 (permalink)
eeeny's Avatar
The electric power steering pump from a 3rd gen MR2 spyder (2001-2005) looks like a better deal as it has a built in oil reservoir.
http://www.autozone.com/R,2253446/ve...ductDetail.htm
Old 01-02-2009, 11:16 PM   #29 (permalink)
Administrator
I believe the earlier 90's pumps have an adjustable valve that will allow you to tune the pressure and feel of the steering.
David
Mk4 Build Thread:
Old 01-02-2009, 11:19 PM   #30 (permalink)
eeeny's Avatar
I'm sure that you could do the same by running the pump on a lower voltage, (using a cheap speed controller .. pwm modulation)
Insurance
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
Breeze Lucas wipers...
Today 12:41 AM
by mjpesky
Last post by mjpesky
Today 10:11 PM
10 Replies, 199 Views
RIP Wheeler Dealers
Yesterday 11:47 PM
by Greg_M
Last post by Radar Pete
Today 10:05 PM
12 Replies, 289 Views
will this work
Today 08:07 PM
by mg2
Last post by mg2
Today 09:33 PM
2 Replies, 58 Views
Metco driveshaft safety...
Yesterday 07:00 PM
Last post by rich grsc
Today 09:28 PM
4 Replies, 171 Views
Surfdog57's build... ( 1 2 )
06-05-2015 08:36 PM
Last post by SurfDog57
Today 09:15 PM
32 Replies, 2,063 Views
Wiper splins?
Today 02:04 AM
by raceral
Last post by BigUgly
Today 09:05 PM
10 Replies, 235 Views
If pondering HF metal...
Today 02:05 PM
by jeepurz
Last post by CDXXVII
Today 08:49 PM
7 Replies, 201 Views
New Coyote builders...
05-15-2016 05:02 AM
Last post by Formulagod
Today 08:44 PM
6 Replies, 1,289 Views
external fuel pump...
Today 07:37 PM
Last post by Hurricane
Today 07:37 PM
0 Replies, 33 Views
Location for Dual CNC...
02-22-2017 09:57 PM
Last post by Cobrakai
Today 07:27 PM
6 Replies, 395 Views
I can't find anyone who...
Today 02:23 AM
Last post by kpt112
Today 07:20 PM
9 Replies, 203 Views
Source for Dash Switches
Today 06:55 PM
by Alan_C
Last post by Alan_C
Today 06:55 PM
0 Replies, 50 Views
FinishLine out of...
Yesterday 12:28 AM
Last post by WIS89
Today 06:45 PM
7 Replies, 642 Views
Saw The Pretenders and...
Today 12:41 PM
Last post by Dan Babb
Today 06:22 PM
2 Replies, 70 Views
Upcoming Simeone Demo Day
Today 06:21 PM
Last post by CJBergquist
Today 06:21 PM
0 Replies, 35 Views
Just another forward...
Today 02:37 PM
by jeepurz
Last post by CraigS
Today 06:11 PM
1 Replies, 111 Views
Annoying warm engine... ( 1 2 )
06-14-2015 02:48 AM
by Bill_VA
Last post by CraigS
Today 06:06 PM
59 Replies, 1,939 Views
Factory Five Cars...
02-26-2015 01:13 AM
by P Wyman
Last post by Real time recon
Today 06:03 PM
4 Replies, 788 Views
Rotary Motor ( 1 2 3 )
12-06-2006 09:59 PM
Last post by ARROWSTEEL
Today 05:51 PM
72 Replies, 829 Views
TomH33 Hot Rod Build
02-20-2017 03:36 PM
by TomH33
Last post by TomH33
Today 05:32 PM
11 Replies, 489 Views
Google
Roadster Forum
4.6L Roadsters
Big Block Roadsters
Non-Ford Powered Roadsters
GTM Forum
GTM Classifieds
GTM FAQ
'33 Hot Rod Forum
Hot Rod Classifieds
Challenge Cars
Road Racing
Autocross / Pro Solo
Drag Racing
Free Photo Hosting
Tires / Wheels
Tops & Tonneaus
Upholstery
Gallery
Audio / Electronics
Car Care
Insurance / Registration
Brakes / Suspension
Ford Big Block Tech
Ford Small Block Tech
Forced Induction / NOS
Fuel Injection Tech
National Events
Southwest
Northwest
NorCal
SoCal
Southcentral
Midwest
Southeast
Northeast
Canada
Off Topic Discussions
Other Car Discussions
Smyth Performance G3F
Parts For Sale / Wanted
Donor Cars For Sale / Wanted
FFCars.com News
Forum Help / Test
