Links to $64K Questions - FFCars.com : Factory Five Racing Discussion Forum
Old 09-23-2008, 02:46 AM   #1 (permalink)
Spotless
ahedmonds's Avatar
Here are a few links on some of the issues people keep asking about and don’t seem to have the time to do a little searching. These are only a sample of the results, but offer a great deal of information on the subject. Some of these problems have been addressed and/or corrected by FFR.
I’ll add to this list as I run across different items. Suggestions anyone?
Builders by State
FFR GTM Builders by State - FFCars.com : Factory Five Racing Discussion Forum
Using Corvette Parts
gtm start
Posting Pictures
http://www.ffcars.com/forums/showthread.php?t=167188
Body to frame height alignment
http://www.ffcars.com/forums/showthread.php?t=176091
Rear Wheel to wheel well fit
http://www.ffcars.com/forums/showthread.php?t=87879
Rear hatch struts
http://www.ffcars.com/forums/showthread.php?t=87380
http://www.ffcars.com/forums/showthread.php?t=87659
Suspension cam bolts
http://www.ffcars.com/forums/showthread.php?t=179183
http://www.ffcars.com/forums/showthread.php?t=178408
Passenger door fit
http://www.ffcars.com/forums/showthread.php?t=168576
http://www.ffcars.com/forums/showthread.php?t=87748
Door stops
http://www.ffcars.com/forums/showthread.php?t=87291
http://www.ffcars.com/forums/showthread.php?t=179462
Use Corvette coolant hose
http://www.ffcars.com/forums/showthread.php?t=170886
Shift linkage
http://www.ffcars.com/forums/showthread.php?t=88006
http://www.ffcars.com/forums/showthread.php?t=87170
Headlight covers
http://www.ffcars.com/forums/showthread.php?t=86646
Seat mounting
http://www.ffcars.com/forums/showthread.php?t=87148
http://www.ffcars.com/forums/showthread.php?t=86508
Seat Installation Instructions
Rear window fit
http://www.ffcars.com/forums/showthread.php?t=192277
Heat and noise abatement
http://www.ffcars.com/forums/showthread.php?t=189171
Dynamat how many square feet? for gtm - FFCars.com : Factory Five Racing Discussion Forum
Hood latch and fit
http://www.ffcars.com/forums/showthread.php?t=179736
http://www.ffcars.com/forums/showthread.php?t=86622
Seat belt concerns
http://www.ffcars.com/forums/showthread.php?t=87917
Rear shock mounting
http://www.ffcars.com/forums/showthread.php?t=87897
Body reinforcing
http://www.ffcars.com/forums/showthread.php?t=172052
http://www.ffcars.com/forums/showthread.php?t=88207
http://www.ffcars.com/forums/showthread.php?t=85991
CV joint issues
http://www.ffcars.com/forums/showthread.php?t=86054
http://www.ffcars.com/forums/showthread.php?t=86074
http://www.ffcars.com/forums/showthread.php?t=173567
CV Joint Prep Video by "Crash"
http://www.ffcars.com/forums/42-fact...-cv-joint.html
Tire and wheel sizes and offsets
http://www.ffcars.com/forums/showthread.php?t=87860
Belt squeal
http://www.ffcars.com/forums/showthread.php?t=190576
Battery size
http://www.ffcars.com/forums/showthread.php?t=193528
http://www.ffcars.com/forums/showthread.php?t=194865
Clutch pedal pressure and fork throw
http://www.ffcars.com/forums/showthread.php?t=86541
Broken Clutch Release Fork Shaft Boss
http://www.ffcars.com/forums/42-fact...52-broken.html
http://www.ffcars.com/forums/42-factory-five-gtm-forum-sponsored-mendeola-powertrain/223916-dang-i-broke-my-new-toy.html
Water pump
http://www.ffcars.com/forums/showthread.php?t=87702
General body fixes
http://www.ffcars.com/forums/showthread.php?p=1505165
COST of build discussion
http://www.ffcars.com/forums/showthread.php?p=1548752
Transaxle oil cooling
http://www.ffcars.com/forums/showthread.php?t=184396
Transmission choices
http://www.ffcars.com/forums/showthread.php?t=185171
http://www.ffcars.com/forums/showthread.php?t=88040
http://www.ffcars.com/forums/showthread.php?t=88052
Transmission weakness
Is this the right gearbox (transaxle)?? - FFCars.com : Factory Five Racing Discussion Forum
Transaxle Inverting
http://www.ffcars.com/forums/showthread.php?t=176478
Clutch Fork install
http://www.ffcars.com/forums/showthread.php?t=199010
G96/50 subframe mod
http://www.ffcars.com/forums/showthread.php?t=198369
Transmission speed calculator
http://www.geocities.com/z_design_studio/transmission_993_bit.html?200713
Transmission gear ratios and ID info
http://www.ultimabuild.com/transmission.htm
LSD
http://www.ffcars.com/forums/showthread.php?t=189225
Storage/Luggage room discussion
http://www.ffcars.com/forums/showthread.php?t=87974
MPG
http://www.ffcars.com/forums/showthread.php?t=188422
http://www.ffcars.com/forums/showthread.php?t=195521
Oil temp sensor
http://www.ffcars.com/forums/showthread.php?t=88262
Twin turbo
http://www.ffcars.com/forums/showthread.php?t=178698
Registration
http://www.ffcars.com/forums/showthread.php?t=196783
Starter
http://www.ffcars.com/forums/showthread.php?t=87498
Air conditioner
http://www.ffcars.com/forums/showthread.php?t=86966
Nice vs Needed
http://www.ffcars.com/forums/showthread.php?t=188963
Tow Hooks
http://www.ffcars.com/forums/showthread.php?t=88235
ABS and Traction Control
http://www.ffcars.com/forums/showthread.php?t=86394
http://www.ffcars.com/forums/showthread.php?t=189433
LS7 with ABS ? - FFCars.com : Factory Five Racing Discussion Forum
AC Compressor Plug
http://www.ffcars.com/forums/showthread.php?t=198222
Steering Lock disable
http://www.ffcars.com/forums/showthread.php?t=86998
GTM Engine Selection Question: How Much HP Really Makes A Difference On The Street?
http://www.ffcars.com/forums/showthread.php?t=227103
Aluminum Cooling Tube Orientation (Cooling System Issues)
Aluminum Cooling Tube Orientation - FFCars.com : Factory Five Racing Discussion Forum
Electronic 4-port Heater Control Valve
http://www.ffcars.com/forums/42-fact...tructions.html
Fuel Tank Leak / Crossover Tube Seal
gas leak - FFCars.com : Factory Five Racing Discussion Forum
Bump Steer and tie rod placement
is this correct? adjustable rod end install - FFCars.com : Factory Five Racing Discussion Forum
Telescopic Steering Relay Wiring
telescopic / steering column wiring - FFCars.com : Factory Five Racing Discussion Forum
Circuit Diagrams
Circuit diagrams - FFCars.com : Factory Five Racing Discussion Forum
Alignment Tips
alignment - FFCars.com : Factory Five Racing Discussion Forum
ahedmonds is offline   Reply With Quote
Old 09-23-2008, 03:31 AM   #2 (permalink)
hitechmotorsports's Avatar
Awesome work, I'm sure this will be very helpful to many people. Wish you luck on your build.
hitechmotorsports is offline   Reply With Quote
Old 09-23-2008, 04:45 AM   #3 (permalink)
samurai41's Avatar
Great job.................................
samurai41 is offline   Reply With Quote
Old 09-23-2008, 10:31 AM   #4 (permalink)
when you do a search you have to click advanced and make sure you select GTM supercar forum. Otherwise, you get all the forums and it is easy to forget to check that.
Which really sucks because you spent a lot of time doing that and it was much appreciated! This might have finally stopped the rediculously repetitive posts
GTM Build Page
GTM#102
Katech LS2 478HP/461TQ, Kooks Exhaust, G50-20 Rebuilt & strengthend, Side Cable Shifter, Quaife LSD, Sachs Organic Clutch, Nordskog Instrument Cluster
Hayabusa02 is offline   Reply With Quote
Old 09-23-2008, 01:04 PM   #5 (permalink)
fuzzyjk's Avatar
Once fixed make it a sticky.
fuzzyjk is offline   Reply With Quote
Old 09-23-2008, 01:10 PM   #6 (permalink)
Spotless
ahedmonds's Avatar
samurai and hayabusa
Had the wrong link copied in my clipboard...fixed now, I hope...Thanks Herb
Kit received 10/28/08, '99 Donor, '97 G50-20-1
Put spot remover on my dog, now he's gone!
Old 09-23-2008, 01:34 PM   #7 (permalink)
+1
Good idea.
jmf003 is offline   Reply With Quote
Old 09-23-2008, 03:31 PM   #8 (permalink)
www.myraceshop.com
+2
BRAVO!!
Well done!
Thank you, thank you, thank you.
crash is online now   Reply With Quote
Old 09-23-2008, 03:42 PM   #9 (permalink)
tracykeyes's Avatar
Haha great work!!! And people thought we were being rude by telling them to do a search and not be lazy.
First time builder! Hopefully not the last.
tracykeyes is offline   Reply With Quote
Old 09-23-2008, 03:49 PM   #10 (permalink)
www.myraceshop.com
1) Never thought you were being rude. MAybe you couldn't see a newbies POV, but you weren't being rude. I understood that the searching should be done, but....
2) I didn't have the time to put something like that together from my work computer without being fired, and...
3) I didn't know the specific questions to ask or key words to use in a search, so it really needed to be done by someone who "has read all the threads on here".
Obviously it was something that many, particularly newbies like me, wanted. Hope it gets stickied. Thanks again.
Old 09-23-2008, 05:12 PM   #11 (permalink)
Just move it over to the Factory Five GTM FAQ forum and put a reminder link in a sticky post here.
MarkH is offline   Reply With Quote
Old 09-23-2008, 05:15 PM   #12 (permalink)
www.myraceshop.com
Great idea.....unless you have actually tried to use the FAQ page. No one can add anything there without "sufficient privelages". Whatever those are.
Old 09-23-2008, 09:31 PM   #13 (permalink)
The Stig's Avatar
Hello Herb, and welcome. There have been many many times where most of us on the forum have stated that this sort of "repository" should be created, but for whatever reason, none of us ever got around to actually doing it... Until you came along.
Good job!
By the way, which HVAC system did you decide to go with?
The Stig
GTM #0081: Some say that I only know two facts about ducks (both being wrong), and that I am illegal in nine US states.[... All I know is that I'm called "The Stig".
The Stig is offline   Reply With Quote
Old 09-24-2008, 12:03 AM   #14 (permalink)
Spotless
ahedmonds's Avatar
Michael,
Bought one from Brion G. Was at my mother-in-laws about 10 miles from him, stopped in and left with the VA system from FF. Have used VA before and adapted Cadillac automatic climate control to it and works fine. That's in my '51 Ford PU. Herb
Old 09-24-2008, 01:13 AM   #15 (permalink)
GTM Newb
NAVY08's Avatar
Thanks for putting the worn in on that. I am in the same position as you, I have the donor and I'm working on getting all the parts, then I will order the kit. Its taking me a while though I have little to no time to work on my project. Good luck with yours, if you are as thorough as you were with this, it will turn out awesome
NAVY08 is offline   Reply With Quote
Old 09-24-2008, 01:37 AM   #16 (permalink)
The Stig's Avatar
Who's building a GTM near you?
GTM Builders Spreadsheet
http://www.ffcars.com/forums/showthr...34#post1720534
The Stig
Old 10-01-2008, 10:54 AM   #17 (permalink)
spdmon2791's Avatar
Bump.
Sticky please!
If you\'re not living on the edge, you\'re taking up too much space.
spdmon2791 is offline   Reply With Quote
Old 10-01-2008, 11:27 AM   #18 (permalink)
GOGGLES PIZANO's Avatar
Icon15 A Big,
THANK YOU,GP.
GOGGLES PIZANO is offline   Reply With Quote
Old 10-01-2008, 11:46 AM   #19 (permalink)
GTM Fan
Good work Herb. This is the same format as the Cobra FAQ, so my vote would be to move it over to the GTM FAQ area so it can easily be found.
________________________
Chad Thomas
GTM #16
Construction Pictures: http://s42.photobucket.com/albums/e3...0Construction/
Modification Pictures: http://s42.photobucket.com/albums/e3...cc/GTM%20Mods/
CUL8R is offline   Reply With Quote
Old 10-03-2008, 12:44 AM   #20 (permalink)
Spotless
ahedmonds's Avatar
Added a few more links 10-02-08.....Herb
Old 10-03-2008, 12:51 AM   #21 (permalink)
65 Cobra Dude's Avatar
I made it a sticky for a little while and then will move it to GTM FAQ's.
Henry
65 Cobra Dude is online now   Reply With Quote
Old 10-03-2008, 02:04 PM   #22 (permalink)
cmainor's Avatar
Excellent sticky move. Thanks Henry!
cmainor is offline   Reply With Quote
Old 10-03-2008, 04:46 PM   #23 (permalink)
www.myraceshop.com
If you move it to the FAQ section, can you make sure it is not locked to the average poster to this forum. I can not post anything in the FAQ section and I don't think most others can either. If it is to be kept a "living" thread/topic, as I believe it should, users must be able to add to the list.
Thanks in advance.
Old 10-26-2008, 03:27 PM   #24 (permalink)
Spotless
ahedmonds's Avatar
Added links 10-28-08...Herb
Google
