More lift questions w/ pictures - FFCars.com : Factory Five Racing Discussion Forum
Old 12-06-2003, 02:27 PM   #1 (permalink)
BillKnight's Avatar
Question
More engine lift questions. If I have legs that extend out. Can I approach from the front?
This is the lift I borrowed. Is it different than the ones used when coming in from the side?(Bigger???)
The picture shows that the legs are fully collasped. I would suppose they go out another 18" or so.
[ December 06, 2003, 10:37 AM: Message edited by: Knightyme ]
KB,331,AFR185,PIN drive,IRS,steering wheel.
BillKnight is offline
Old 12-06-2003, 03:05 PM   #2 (permalink)
Male Member
mrpink's Avatar
Looks just like the hoist I used. In from the front no prob.
mrpink is offline
Old 12-06-2003, 04:43 PM   #3 (permalink)
You'll need to extend the boom to the 2000lb mark.
Other user name is LarryD
pan61 is offline
Old 12-06-2003, 04:45 PM   #4 (permalink)
If you extend the boom - then extend the legs.
When you put weight on the boom, the end of the legs become the vulcrum for tip over. The closer to being under the weight the safer. [img]smile.gif[/img]
[img]graemlins/green.gif[/img]
StephenP is offline
Old 12-06-2003, 04:50 PM   #5 (permalink)
With the legs extended to their maximum length and setting the boom at 2000 lbs. picking up the engine with the transmission attached was no problem, especially with the engine leveller.
misu(Allan) [img]graemlins/black.gif[/img]
FFR3822 - Currently Under Construction
Misu is offline
Old 12-07-2003, 04:02 AM   #6 (permalink)
VPR-KLR's Avatar
Same lift
Legs extended to max length
Boom to 2000lbs
Engine leveler
Body on
front wheels on 2x4's
Front insertion, no problem
VPR-KLR is offline
Old 12-07-2003, 04:30 AM   #7 (permalink)
BillKnight's Avatar
Thank You, I knew I would find the answers here!
