I think I made out on some Performer RPM's - FFCars.com : Factory Five Racing Discussion Forum
Old 12-03-2003, 04:46 AM   #1 (permalink)
FFR Craftsman
289FIA_Cobra's Avatar
I was on a local Ford forum (SF Bay Area) and came across someone that was selling a used set of Performer RPM heads and roller rockers. I was a bit skeptical since he offered $500 for "everything". From the top of my head, I figured it was just over $1300 new so perhaps $500 is good considering it's used. So then I call him and he indicated it wasn't used much; maybe 100 miles! And it would also include push rods and all the bushings and bolts necessary to bolt onto a block. So I went to the bank and got $500 and drove up. After looking over the heads, I realized that he might of been honest; the "rust" in the water galley were just surface stuff I could rubb off to reveal aluminum underneath. Checked for any chips/cracks in the head and valves but nothing eveident. The casting shows "6025" which is the Edelbrock 60259 with 2.02" in/1.60" ex. (I measured them later as well). The roller rockers are CompCams 1.6 ratio (red anodized). Appears all the bolts and bushings are present. I added this all up from Summit Racing and if all of this was bought new, I was looking at $1454.59 (and I fogot about the pushrods). I just counted my lucky stars on this one because I wasn't sure if this was a good deal or not but time was running out on it as someone else was inquiring about it too; my gut said it was a helluva deal - what do you guy's think??? here's a few pics i took:
Notice on the chamber on the far right that I cleaned a little; that was just with a few shots of carburator cleaner a some swipes with a rag.
Project: SNKVNNM
289FIA_Cobra is offline
Old 12-03-2003, 04:54 AM   #2 (permalink)
Out-of-control teenager
Max_Thompson's Avatar
Good find! Those are a nice set of heads (we have em' too, good power).
If you are still concerned is there any test you can do for damage (magnaflux rings a bell, does this work for aluminum)?
Max_Thompson is offline
Old 12-03-2003, 07:47 AM   #3 (permalink)
The Never-Ending Builder
Hankl's Avatar
Herman,
Christmas came early!
Check to make sure the springs have good spring seats, some of the early RPM's had bad ones.
Hank
[img]graemlins/darkbluecoupe.gif[/img]
“If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
Hankl is offline
Old 12-03-2003, 10:19 AM   #4 (permalink)
Icon4a
Great buy,I have the same heads also and I top it off with a Vortech blower,gobs of torque and h.p.
[img]graemlins/yellow.gif[/img]
Nelson Abinsay is offline
Old 12-03-2003, 09:05 PM   #5 (permalink)
FFR Craftsman
What's a good method for getting out the surface rust in the area's I can't reach? TIA.
Project: SNKVNNM
Old 12-03-2003, 09:37 PM   #6 (permalink)
Administrator
David Borden's Avatar
Great deal!!! FYI, you cannot run stock pistons with those heads. You will need to get new ones, or have your existing pistons notched. You wont have enough valve clearance.
David
David Borden is offline
Old 12-03-2003, 09:38 PM   #7 (permalink)
Hankl's Avatar
Don't worry about the rust, non-item.
Hank
Hankl is offline
Old 12-03-2003, 11:37 PM   #8 (permalink)
In FFR-building hiatus
Joe Campbell's Avatar
I just sold a set of those not too long ago for $900 shipped. I certainly wouldn't let a set of those go for $550 unless I was desperate for cash!
You might wanna check for warpage, just in case.
'11 Mustang 5.0 'vert; '07 Legacy Spec.B; '98 F150; 4760 build website; FFR 3144 rebuild blog
I'll give up my clutch when they pry it from my cold dead toes.
Si vis pacem para bellum.
Joe Campbell is offline
Old 12-03-2003, 11:48 PM   #9 (permalink)
BE CAREFUL.... I've seen a lot of used heads that were junk. Remember the old addage... If it sounds to good to be true.... I would have a good "head man" look them over. Good luck, Randy Richards
FFR-4262, 347 stroker,EFI, Trick Flow heads,intakes,#2 cam. Tremec TKO,4-link 8.8,3.55 gears,Ford pearlcoat red,silver stripes. On the road 9/04
G4AV8R is offline
Old 12-04-2003, 12:08 AM   #10 (permalink)
Hoosier's Avatar
It's a good idea to go ahead and heli-coil those spark plug holes while you have them off the engine.
Ask me how I know????????
-Andrew-
Hoosier is online now
Old 12-04-2003, 07:29 AM   #11 (permalink)
smg
magniflux works only on iron heads, the non-magnetic nature of aluminum won't work. i believe they use a die that shows up dark on the cracks under a black light when magnitized.
smg is offline
Old 12-04-2003, 12:30 PM   #12 (permalink)
Ozona's Avatar
If they're perfect (they look good in the picture) you got a steal!! Hopefully the previous owner didn't get 'em that way too.
FFR 3478 - 377 SC, Silver / White
Ozona is offline
Old 12-04-2003, 01:50 PM   #13 (permalink)
Zy-glow is used to check alum for cracks. Edelbrock heads have helicoils from the factory. That was an outstanding purchase!
Marc A
Marc A is offline
