Front LCA Question - FFCars.com : Factory Five Racing Discussion Forum
Old 12-03-2003, 11:03 PM   #1 (permalink)
cwood's Avatar
With the lower control arm to frame bolts torqued to spec, how stiff should the up and down movement be? With all assembled I have to pull pretty hard on the spindle to get up and down travel...I'm assuming with full car weight this is not an issue
Chuck
FFR #4758-IRS-Pin Drive widths - 351W - 3.55's - Tremec 3550 - 15" PSE GT-40, 295's ----- SOLD
Build Gallery:
http://picasaweb.google.ca/chuck.tat...eat=directlink
cwood is offline
Old 12-03-2003, 11:22 PM   #2 (permalink)
Sounds just about right to me. The manual mentions something about making sure that you torque them while they are parallel with the ground.
drew
ffr4408, p.d. irs, 373\'s, tremec 3550, 302, trick flow twisted wedge heads, trick flow cam, edelbrock air gap intake, holley 650dp, tristate 4-into-4\'s and msd all around.
aherrmann is offline
Old 12-03-2003, 11:25 PM   #3 (permalink)
Hoosier's Avatar
I have been told you should leave these loose, or loosen them back up, when you adjust your ride height. Or else, the rubber bushings will always be in a bind. Same with the rear............
Mine are also very ridgid.
-Andrew-
Hoosier is online now
Old 12-03-2003, 11:26 PM   #4 (permalink)
bill32's Avatar
Mine were stiff, but you have to remember that you have put a lot of torque on those bolts, pinching the steel sleves that are inside the bushings. Don't forget to loosen those bolts before you put on the rest of the suspension, and leave them loose until you are don't with the car. You don't tighten them until you set the ride height, with the car jacked up, stands under the suspension, not the frame.
Roadster #3358K, Spec Racer #2889 SP, Daytona Sypder GT #4569GT (#8 of 39).
bill32 is offline
Old 12-04-2003, 03:12 AM   #5 (permalink)
Supermoderator
oldguy668's Avatar
The question can't be answered correctly until you tell us if you have stock donor LCA's or FFR tubular units.
Mark Twain
oldguy668 is online now
Old 12-04-2003, 05:30 AM   #6 (permalink)
Babe Ruth's Avatar
Smile
In addition, if all your bushings are poly, you can go ahead and torque them before setting the ride height.
Babe Ruth [img]graemlins/blue2.gif[/img]
Babe Ruth is offline
Old 12-04-2003, 12:31 PM   #7 (permalink)
cwood's Avatar
FFR Tubular ....Old Guy
Chuck
Build Gallery:
cwood is offline
