Simple questions need simple answers - FFCars.com : Factory Five Racing Discussion Forum
Old 08-05-2002, 07:19 PM   #1 (permalink)
1. If FFR is sending a new steering column, do I still need any part of the donor one?
2. Is a 4 cyl. wiring harness the same as a 5.0 except for the engine compartment?
3. Any way to tell what the gear ratio is in a T-5?
falcon2500 is offline
Old 08-05-2002, 07:22 PM   #2 (permalink)
2FAST4U's Avatar
Answers:
1) No, if the FFR supplied column is the one-pice (no weld) design.
2) Don't know
3) http://www.fortesparts.com/tremec/t5.html
Keith
Bill D
RCR GT40 - 1051P clone, $old
289 FIA currently in work with Mr. Bruce, 331, dual quads, T-5, and IRS
http://www.bills289fia.com
2FAST4U is offline
Old 08-05-2002, 07:36 PM   #3 (permalink)
Don't you still need the upper steering shaft from the Mustang; the part where the steering wheel attaches? Or has FFR gone to a 1-piece shaft from the rag joint to the steering wheel?
Paul Burchett
\"Nothing is foolproof because fools are so ingenious.\"
paul burchett is offline
Old 08-05-2002, 07:48 PM   #4 (permalink)
Horizon200's Avatar
If they haven't gone to an all one piece, can a 4cyl steering shaft be used? My donor has the tilt wheel and so I'll need to pick up a non tilt from a junk yard methinks.
\"HABU\" FFR 3817 Redfire w/ Silver Stripes Stock build w/ 3:73\'s/Mass=Flo/Dual Roll Bars/Street Performers(finished 28 Feb 2004)
Horizon200 is offline
Old 08-05-2002, 08:02 PM   #5 (permalink)
CobraEarl's Avatar
David smith talked briefly about this when he was on the chat room a week or so ago. IF i remember correctly, he said they had done away with the need for the donor part on the steering column.
you can review the chat transcript or just call them and ask..
report back about what you found out.
earl
See all of the "COBRAEARL's Creature Comfort FFR Accessories" HERE!
CobraEarl is offline
Old 08-05-2002, 08:06 PM   #6 (permalink)
A 4 cylinder, non-tilt steering column will work. I'm curious about what FFR has changed. The spec racer always came with a one piece lower shaft; no welding the donor shaft. I thought they had just made the one piece lower standard on the roadster.
[ August 05, 2002, 04:11 PM: Message edited by: PAB ]
Paul Burchett
Old 08-05-2002, 08:15 PM   #7 (permalink)
What Paul said!
RR
Never Tease A Tiger!
RacingRob is offline
Old 08-06-2002, 07:01 PM   #8 (permalink)
UHH anyone know about the wiring harness?
