Hazard Switch Replacement - FFCars.com : Factory Five Racing Discussion Forum
Old 08-29-2002, 09:16 PM   #1 (permalink)
grok's Avatar
Question
Anyone find a good hazard switch replacement?
I am looking for a DPST On-On switch (12V Heavy Duty) so that when the hazards are selected they power all of the markers (from [385 or 8]) and when off the turn signals are powered (through [44]). (No Lucas NOS is available for this application and I do not want to use the donor switch)
A red (possibly lighted) paddle toggle would be a bonus. I would mount a rocker type switch on the bottom flange of the dash.
Former owner of FFR #3136
grok is offline
Old 08-29-2002, 09:42 PM   #2 (permalink)
wnstwolf's Avatar
After a long search I found a lighted red toggle in Mcmaster car..
Wired everything up and realized it messed up the individual left/right thing due to cross wire of lights.. What I am trying to say is that even with the diodes in place the switch in the off position when I used the turn signals lefts and rights would come on..
After a lot of aggravation I went with two mini rocker switches mounted to the under side of the dash on the left side.. The rockers were mounted to the plate that the donor would have gone on (looks like an "L" with a square cut out of the middle.) I just reach down and with two fingers operate the switches simultaneously ( yeah thats spelled right)
out of the way and works but would have liked the single throw double poe to work and light up..
oh well
Upstate NY. Moved in and starting to work in the garage and not on it!
wnstwolf is offline
Old 08-30-2002, 01:42 AM   #3 (permalink)
grok's Avatar
Icon19
Sounds like a possible alternative. I was thinking of adding a Normally Closed Relay to a regular SPST On-Off Red switch. I just can't believe that nobody makes a switch like those old double blade (mousetrap) style knife switches Alexander Graham Bell used.
...Or I can find a DPDT On-On 6P switch with no middle position!! Now to find a red one.
[ August 29, 2002, 10:27 PM: Message edited by: Grok ]
grok is offline
Old 08-30-2002, 02:56 AM   #4 (permalink)
A pair of diodes will fix the cross wiring. They act as one way valves for current. I found two diodes in my donor harness that worked perfect. They were even labeled properly. Just wire them in with the arrows pointing away from your switch. One diode conects to your left turn signal circuit and the other to the right.
Viper Blue/White F5 Cobra, 5.0 EFI, E Cam, 17\" PSE Wheels, Rag Top, AC and Heat
Red and Grey RCR GT40, and a Coper/Black GTM LS1 G50/05 COMPLETED.
Jonathan is offline
Old 08-30-2002, 04:11 AM   #5 (permalink)
I used a 3PDT relay to replace the donor switch. Any SPST switch can be used to control the relay. I'm not sure the diodes in the donor harness will tolerate ~4 amps flowing through them for very long. Volts x Amps = Watts Most diodes are rated for a watt or less.
[ August 30, 2002, 12:14 AM: Message edited by: PAB ]
Paul Burchett
\"Nothing is foolproof because fools are so ingenious.\"
paul burchett is offline
Old 08-30-2002, 04:06 PM   #6 (permalink)
grok's Avatar
Smile
Yes, Last night I realized that a 3PDT On-On switch would work as well. No diodes needed. Where did you find yours? Anyone out there know if there is a 6A or greater (preferably red) 3PDT two posistion 9 pin On-On switch available?
grok is offline
Old 08-30-2002, 04:38 PM   #7 (permalink)
Like I said, I used a relay which is controlled by a SPST switch. Go to www.mscdirect.com Enter 54038534 into the search engine for the relay.
Paul Burchett
