Aluminum shears/cutters? - FFCars.com : Factory Five Racing Discussion Forum
Old 08-07-2002, 05:35 PM   #1 (permalink)
Question
Just reading a few posts which are mentioning trimming certain aluminum panel pieces...
What is your tool of choice for the trim work?
Just hand clippers? Pnuematic clippers? Other?
Enquiring minds want to know.
I already have my pneumatic riveter on its way from Harbour Freight...SHOULD be here already.
Got my Cleco pliers and Clecos from Aircraft Spruce.
I'm sure there will be a hundred more tools I'll buy between now and completion.
Thanks!
Neill
Current ride: 2000 Corvette Coupe (Millenium Yellow)
FFR3673K Open manual to page 1...LMAO!! FFR 65 MKII (will be yellow)
418W C.I./ 515 HP, 3.42\'s, Fuel Safe, IRS, Cobra \'R\' Brakes, Street Performers, Dual Hoops, AutoMeters, 17\" rims & tires(245/45, 275/40).
BatMobile is offline
Old 08-07-2002, 05:59 PM   #2 (permalink)
You might want to check these threads out:
http://www.ffcars.com/cgi-bin/ultima...c;f=1;t=002287
http://www.ffcars.com/cgi-bin/ultima...c;f=1;t=003381
http://www.ffcars.com/cgi-bin/ultima...c;f=1;t=003565
Having said that, for trimming the panels I used a combination of tools:
Good quality aviation (tin) snips - must have!
3" air powered cutoff tool - nice to have.
30" shear/brake/bead roller - schweet! but not really needed.
Have fun!
FFR Roadster #3440, No donor build. \'99 Cobra alum IRS with 3.55\'s, powered by Vortech SQ blown, 428 HP/444 ft-lb Levy Racing Stage 3 EFI 306, T5Z, CoolParts steering shaft, Wilwood 13\" front and 12\" rear brakes, SN95 front susp w/ FFR lowers, FR 15-1 rack, 17x9 and 10 Image wheels, Autometer Ultra gauges, Levy Racing Stage 2 suspension. Porsche Red with White Stripes, courtesy of SRP\'s fine work.
dbarrym is offline
Old 08-07-2002, 10:07 PM   #3 (permalink)
Supermoderator
oldguy668's Avatar
Don't laugh, guys. For the limited amount of cutting I had to do, I used a small table saw with a metal cutting blade and the rip fence. It actually worked pretty well, but I'll admit it's not "period correct"
Happy motoring
Mark Twain
oldguy668 is offline
Old 08-07-2002, 10:13 PM   #4 (permalink)
Thanks for the links Barry...
:cheers:
Old 08-07-2002, 11:35 PM   #5 (permalink)
Depending on the particular problem, I used my Dremel with the cutoff discs alot.
RR
Never Tease A Tiger!
RacingRob is offline
Old 08-08-2002, 12:45 AM   #6 (permalink)
Aviation shears, which are fancy tin snips, seem to work well on the fairly hard alloy that FFR uses for the panels. There are left and right cut shears and also straight cut . The left/right ones cut straight or, you guessed it, left or right. You really cannot make the right or left cut left or right, so you'll need both, About $15 each for pretty good ones. I'd avoid the cheapies on these.
I have had remarkably good luck making nice round holes up to about 1.5 inches using a 1/8" pilot hole and Irwin "Speebore" bits. These are spade bits for woodworking, but unlike some other brands, they have little "spurs" at the edge that do a really nice job of making a nice, round, clean, hole. Better and cheaper than a twist drill especially in the larger sizes. Just go slowly and it works great.
Ed T is offline
