Track rod ends siezed - FFCars.com : Factory Five Racing Discussion Forum
Old 10-30-2002, 12:50 PM   #1 (permalink)
2savage's Avatar
title says it all. Tried heat, no luck. The rack is installed already. Any ideas?
2savage is offline
Old 10-30-2002, 04:21 PM   #2 (permalink)
My .02
soak in penetrating oil overnight. Big wrench (vicegrips maybe?) to hold the tie-rod end and another on the lock nut. Should be able to break it loose. Last resort......upgrade to Flaming river rack and new tie-rod ends
TEC
Cheers
TEC
\"To err is human. It takes a computer to really foul things up\"
FFR 3674:Levy racing stage 3 motor and T-5Z Trans.Go-kart stage ,3link, 3.55 gears,Smith\'s gauges,Cobra R Wheels,body at SRP\'s, color will be Brittany Blue w/ pearl white stripes Build Site
Tim Cronin is offline
Old 10-30-2002, 04:32 PM   #3 (permalink)
2savage's Avatar
No problem with the lock nots; it's the rod and the tie rod end that won't budge. I like the flaming river idea though apart from the [img]graemlins/money.gif[/img]
2savage is offline
Old 10-30-2002, 04:45 PM   #4 (permalink)
Champagne Tastes on a Beer Budget
If the penetrating oil/vise grip approach isn't enough, take the rack back off the car and clamp the rod "gutentite" in a vise. A wrench on the tie rod end should then give you enough leverage to break it loose. Worked for me on my rusty donor.
Good luck,
slapshot
FFR #2015
slapshot is offline
Old 10-30-2002, 04:53 PM   #5 (permalink)
I used penetrating oil (PB Blaster), vice grips and a very BIG wrench. Sometimes a bit of temperature cycling with the old blue wrench helps too.
Phil
FFR 3785
Pro-M ATI 75mm MAF, Accufab 65mm TB, Trick Flow Street intake, AFR 165 heads, 1.7 Crane roller rockers, 42lb injectors, 255lph fuel pump, March underdrives, Crane HI-6 ignition with Fireball coil, TwEECer tuned by me!!
FrankenCobra is offline
Old 10-30-2002, 04:56 PM   #6 (permalink)
Use a good air hammer and rattle on the tie rod to break the rusty grip the tie rod has on the rack. Then put a wrench or a vise grip on the rod and a wrench on the tie rod. It's what the pros use. (unless its really stuck, then heat is an option if you're going to replace the tie rod).
Jason
FFR2710: 400+RWHP, Vortech blown all Trick Flow 302, 3.27 IRS, Cobra R\'s, Tremec. Bodyman is finally ready for my car, Soon to be Lambo orange!
JasonD is online now
