Butcher #51 - SETTING VALVE LASH - FFCars.com : Factory Five Racing Discussion Forum
Old 05-22-2002, 08:08 PM   #1 (permalink)
Talking
<font face="Impact" size="7" color="#FF0000">SETTING VALVE LASH</font>
Click Here to read the latest adventure
andy dunn is offline
Old 05-22-2002, 08:36 PM   #2 (permalink)
Tom Keiser's Avatar
Thumbs up
Andy,
Well done and informative as always. Thanks for keeping us up to date. Tom [img]graemlins/red.gif[/img]
FFR2636,Viper Red/ Arctic White. V1-SC Supercharged 308. T5Z, 3:73 3-Link rear, PS GT40 wheels, 5 lug w/4 wheel discs
Tom Keiser is offline
Old 05-22-2002, 10:07 PM   #3 (permalink)
Andy...you never cease to amaze me. You could teach yourself...and then us...how to build, maintain and fly the space shuttle [img]smile.gif[/img] .
Rick Williams is offline
Old 05-22-2002, 10:52 PM   #4 (permalink)
forrest1's Avatar
Andy,
Excellent! I love reading your stories!
Forrest
Former Owner/Builder FFR 2433
forrest1 is offline
Old 05-23-2002, 03:04 AM   #5 (permalink)
thanks guys
I just wanted to make one additional note to the story. It's been suggested that my method of randomly bumping the engine around and hunting for loose rockers is perhaps not the safest method Here is the method from Crane on positioning the rockers at the proper point for adjustment.
1. When the engine is hot (at operating temperature) remove the valve covers and pick the cylinder you are going to adjust.
2. Hand turn the engine in its normal direction of rotation while watching the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder’s intake valve. (Why? Because when the exhaust is just beginning to open, the intake lifter will be on the base circle of the lobe, so the intake is the one we can now adjust.)
3. Use a feeler gauge, set to the correct valve lash, and place it between the tip of the valve stem and rocker arm. Adjust until you arrive at the proper setting and lock the adjuster in place.
4. After the intake valve has been adjusted, continue to rotate the engine, watching that same intake valve. The intake valve will go to full lift and then begin to close. When the intake is almost closed, stop and adjust the exhaust valve on that particular cylinder. (Again, when we see the intake valve almost closed, we are sure that the exhaust lifter is on the base circle of the lobe.) Use the feeler gauge and follow the procedure described before in step 3.
5. Both valves on this cylinder are now adjusted, so move to your next cylinder and follow the same procedure again. In the future you may find shortcuts to this method, but it still remains the best way to do the job correctly.
Andy
Old 05-23-2002, 04:13 AM   #6 (permalink)
Andy...thanks for posting all that info!!! You went with a solid cam..ehh?? You gotta email me the specs so I can compare it to my "cam of choice". I hope you make 485 HP at the wheels...but I think maybe 410-415 is more realistic. Please keep us informed...can't wait until you post your dyno numbers!! dino
d boothe is offline
Old 05-23-2002, 04:30 AM   #7 (permalink)
Supporting Vendor & Admin
Wayne Presley's Avatar
Andy, I was disappointed with your report. Only one instance of breakage in the whole article and it was just a tool....And you only had to do the adjustment once, so unlike you(3 throw out bearings,2 motors 2 distributors...)
[ May 23, 2002, 12:31 AM: Message edited by: Wayne Presley ]
Wayne Presley
www.verycoolparts.com
Wayne Presley is offline
Old 05-23-2002, 05:40 AM   #8 (permalink)
Icon2a
Andy, informative, entertaining, glib, humorous, and extremely excellent writing. Love your stuff, dude. Matt [img]graemlins/green.gif[/img]
If you must continue to groan, please do it in a dancing rhythm.
Matt M is offline
