Frame mods for Power Brake booster - FFCars.com : Factory Five Racing Discussion Forum
Old 10-29-2002, 10:57 PM   #1 (permalink)
Can someone tell me the easiest way to modify the frame to use the stock mustang power booster., possibly post some pics of your setup. What additional brake line issues did you run into..gotta go do some rivetting...I'll check back here later..Thanks
Don Maggiore
FFR 3839 Viper Blue, White Stripes Autometer phantoms, 302 EFI 6psi Powerdyne Supercharger, PS Engineering, 190LPH FMR Fuel Pump, 3:55 rear
DPMAZ is offline
Old 10-29-2002, 11:35 PM   #2 (permalink)
Go to Sears hardware and buy a 3 foot long piece of 3/4 sqaure (matches the frame. Cut the chassis in front of the footbox on the drivers side of the car and where the F panel end. cut the new piece to size and weld under where the original chassis piece was located. You'll also need to enlarge the hole for the master cylinder - Suggest you do a search on brakes or power brakes. There was a good thread on it a few weeks back (with pictures).
YOU CAN NEVER OVERDOSE ON ADRENALINE.
FFR #3758 - narrowed 8.8 axle w/3.55, FMS 302 w/GT40 aluminum heads and GT40 intake, 4 into 4 headers, PSE 15\" Wheels, power brakes, heater.
KobraKurt is offline
Old 10-29-2002, 11:51 PM   #3 (permalink)
Supermoderator
oldguy668's Avatar
Use the search function as Kurt suggested and also check the FAQ. There are hundreds of postings and dozens of pictures.
Mark Twain
oldguy668 is online now
Old 10-30-2002, 01:22 AM   #4 (permalink)
forrest1's Avatar
Also look here:
http://www.norcal-cobras.com/project...owerBrake1.htm
Forrest
Former Owner/Builder FFR 2433
forrest1 is offline
Old 10-30-2002, 01:59 PM   #5 (permalink)
Grand bodger
DeepThought's Avatar
I plan to cut and weld a curved piece into the frame. I am also here in PHX. I would be happy to do yours first
I don't use turn signals, it reveals my plans to the enemy!
DeepThought is offline
Old 10-30-2002, 02:13 PM   #6 (permalink)
Has anyone tried to heat the tube bright red and then bend it so it clears? Looks like it only needs to move about 3/4"
stang8s is offline
Old 10-30-2002, 03:30 PM   #7 (permalink)
mikiec's Avatar
Don,
Just cut it or have Deep thought do it for you....Then get on with your build. Remember there is lots you can do. Oh, That power coated frame looks cool..If you need more money for additional items you could always sell the Harley.
Deep Thought....for you to get to Don's house you will need to pack a lunch. Actually he is about 50 miles from you. Which out here is not far at all. You both can colaborate on your builds. There is a third build starting here in about 2 more weeks.
All gave some, Some gave all. Rest peacefully my brothers.
http://s210.photobucket.com/albums/bb222/mikiec66/
mikiec is offline
Old 10-30-2002, 03:53 PM   #8 (permalink)
JimmyHunt's Avatar
Icon23
Forrest - How did the '86 Mustang SVO Turbo 4cyl Master Cylinder (NM1897 at Autozone, $52.99), work out with the Wilwood proportioning valve for the rear discs?
[img]graemlins/orange.gif[/img]
FFR#2599 Mark 2, FMS 351W, Tremec 3550, I Squared Wiring System, Cobra Brakes, IRS,Pin Drive Rear, Edelbrock Pro-Flo EFI, Edelbrock Nitrous, Tristates 4-4, 17\" Compomotive HB, Quality Roadster A/C, Delv\'d 3/30/02.
JimmyHunt is offline
Old 10-30-2002, 04:15 PM   #9 (permalink)
Wade Chamberlain's Avatar
The problem is the tube really needs to be moved 3/4" within about 1/2" of where it's welded to the front wall of the footbox framework. I don't think you could move it as far as you need to without cutting/welding.
Wade Chamberlain
FFR2229K
Wade Chamberlain is online now
Old 10-30-2002, 04:18 PM   #10 (permalink)
Question that comes to mind everytime i read one of these threads is... Why dont they just build them with the tube moved or curved?? There must be some reason.
stang8s is offline
Old 10-30-2002, 04:54 PM   #11 (permalink)
mikiec's Avatar
It is my understanding that the factory does not think power brakes are needed. Therefore, the car is not setup to use the power brake system.
I think it would be a good idea to revisit this area. SPF's come with power brakes standard.
mikiec is offline
Old 10-31-2002, 02:06 AM   #12 (permalink)
forrest1's Avatar
Jimmy,
The SVO m/c worked fine, except the one I had always leaked a little bit at one of the fittings (I think the threads or seat must have been messed up), and it was a PITA to check the fluid. It was a big cast iron monster with separate cast-in reservoirs. The only way to fill it easily was by removing the wheel and splashguard and filling it from below with a mirror. If it wasn't for the annoying leak, though, I'd probably still have it.
Now I'm using a 1993 Mustang Cobra 1" m/c (PartsAmerica.com, part # 12669, $64.99), from which I have removed the plastic reservoir and replaced it with a remote reservoir from a Nissan Quest/Mercury Villager minivan (1993 to 1998 or so)(boneyard, $20). This works great! No leaks, and the reservoir is easy to reach!
Either m/c works well with the booster as far as stopping power, etc., and both require a clearance hole in the splashguard.
Stang8s,
It would be really easy for the factory to move the 3/4" tube, just as it would to angle the 3/4" tubes that mount the footbox so that it would line up properly to the firewall. They don't seem to see the need, but, hey, they did finally put in an arched trunk hoop, so who knows?
Forrest
forrest1 is offline
