Need traction - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Competition > Drag Racing
Old 11-09-2011, 01:49 AM   #1 (permalink)
Brad Hinckley's Avatar
Icon21 Need traction
2003 Mark 2 8.8 4 link ffr tubular arms upper and lower with coil overs and still have quad shocks. using middle hole on upper arms with 300-350 hp engine with no wheel hop problem.
Have increased HP and torque on new motor to 550 HP 525 TQ(flywheel)
My pionion angle is -1degree or so now.
Was thinking on getting adjustable upper arms to dial in the pinion angle, but wonder which hole would be best for weight transfer or instant center if trying to get the best launch (I do not auto cross or race this car it is mainly a street cruiser,but I what it to hook up.)
Thanks Brad
Brad Hinckley is offline   Reply With Quote
Old 11-09-2011, 02:45 AM   #2 (permalink)
Qwik 1's Avatar
Brad I believe the lowest hole on the upper arm would give you the best bite. Pinion angle may be okay considering how stiff these cars are. Might be better however with -2 or -3 degrees. You can ditch the quad shocks.
550hp? WOW! What's the setup?
A government big enough to give you everything you want, is strong enough to take everything you have. Thomas Jefferson
Best ET 10.44 @127 mph http://www.youtube.com/watch?v=-whV_8NhNXk
Qwik 1 is online now   Reply With Quote
Old 11-09-2011, 03:04 AM   #3 (permalink)
Icon22
Thanks that was the direction I was leaning to.
351 stroked to 408 ci 750 quikfuel carb on Edelbrok RPM manifold roller cam and rockers ported and matched AFR heads, balanced and blueprinted 10.5 to 1 compression 13 lb alum flywheel. spec 2 clutch TKO 600 .82 3.55 gears
Thanks again for the reply Brad
Old 11-09-2011, 05:32 PM   #4 (permalink)
No Tread TommyG's Avatar
I bet that feels like a whole new animal : )
If you don't already have them, I'd suggest drag radials as well (Mickey Thompson or Nitto NT05R).
Have fun!
Tom
No Tread TommyG is offline   Reply With Quote
