Recommendations for "Best" Autocross Tire & Wheel setup - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 11 (permalink) Old 11-06-2013, 07:52 PM Thread Starter
FFRCobraPoison's Avatar
I am currently runing a MK3.1 in autocrosses, and it is clear to me that my tires are just not up to the challenge. I would like to purchase a set of wheels and tires, specifically for Autocross and Track time.
I am running the 17" Halibrand Replicas, sold by FFR and would like to stick with similar size tires and wheels.
Front Wheel Size (Diameter x width): 17"x 9" 6.00" Backspace (24mm offset)
Rear Wheel Size (Diameter x width): 17"x 10.5" 6.7" Backspace(27mm offset)
Wheel Lug Pattern: Ford style 5 lug x 4.5" bolt circle
I am currently running Nitto 555 Tires.
Front: 245/45 R17
Rear: 315/35 R17
I am considering A6 Tires but was wondering what others had experience running, good/bad & Neutral
MK3.1 Picked up 06/06/2009. FFR #7000 RDS
3-link 3.73; TKO600; 393W 500Hp/490TQ
If your not 1st the view never changes!
FFRCobraPoison is offline
post #2 of 11 (permalink) Old 11-06-2013, 08:38 PM
MJN
MJN's Avatar
275 / 315 A6's will fit those rim sizes and would be the right choice for what you are looking for.
Mike....
MJN is offline
post #3 of 11 (permalink) Old 11-06-2013, 09:20 PM Thread Starter
A6 or R6 ???
post #4 of 11 (permalink) Old 11-06-2013, 10:36 PM
Cone Basher's Avatar
Talking
You want the A6 for Auto-x, the R6 is a slightly harder compound for RR use. The R6 takes a while to warm up. I had them on my old Auto-X corvette and they do not start to grippy until you have about 3 runs on them. The A6 will bite on the first run and get better as they heat up a bit. If it a warm day you might have to spray them down after 3 runs as they get so soft. They are very sensitive to alignment specs and tire pressure so if you choose them check pressure often. I run 275 F 315 R on my Coupe and I've see 295 F on some Roadsters if you have the correct rim with and you are willing to run a lot of caster. You should get about 100 runs on them before you need new ones assuming you trailer your car or use a trailer to haul them. They are very soft and will pick up all kinds of grit. I often find small pieces inside my car after an event.
CB
Cone Basher is offline
post #5 of 11 (permalink) Old 11-06-2013, 11:24 PM
I'v tried them all. Your choices are slightly limited by available sizes. For example, you can't use a Hankook. I trailer the car to the track.
Hoosier R6 is a fast tire out of the box. But it quickly degrades. It will heat cycle out before it wears out. You also need a fair amount of camber to get good use out of it; like 1.75-2.25*
Toyo 888 was a terrible tire. It quickly got greasy and became less than useless. I got rid of them long before they wore out.
BFG R1 was pretty good. But it uses a higher inflation pressure, and that gives it a stiffer side wall. If the track is rough it will bounce you around a bit, and unsettle the suspension. I think it would be a good tire for a heavier car, like a Mustang.
Kumho V710 is my favorite tire. It is about the same cost as the Hoosier. But it stays fast a lot longer, and won't heat cycle out as quickly. I can get almost a whole season out of them. It works well with a lot less camber; like 0.5-1.25*.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is offline
post #6 of 11 (permalink) Old 11-07-2013, 03:00 AM Thread Starter
I can trailer to and from the tracks, primarily looking for autocross for next summer with "A" class road racing. While it sounds like the A6 are a good tire for what I will be using it for....What about wheel recommendations.
post #7 of 11 (permalink) Old 11-07-2013, 01:54 PM
All the DC area FFR autocrossers are running A6s. Wade tried the newest BGF Rival and took them off after one event. 275s or 295s on the front and 315s on the rear. All of us are running wheels the same sizes as you have.
Anthracite Mustang Bullitt Wheel - 17x9 (94-04 All) - Free Shipping
Anthracite Deep Dish Bullitt Mustang Wheel (17x10.5) (94-04 All) - Free Shipping 28111
You will need to get a garden sprayer to water the tires down on hot days. The max 140 deg that Hoosier states is way too hot. Since the label stuck on the tire is mostly purple one guy calls them purple crack. Once you run A6s you will never want anything else.
FFR 5353K, 408W, TKO 500, 3-link w/3.31 and CF clutch pack limslip, Breeze QA1 DA coilovers front and rear, APE hardtop, Forte front and VPM rear swaybars
CraigS is offline
post #8 of 11 (permalink) Old 11-07-2013, 10:43 PM
Cone Killer
P_Matt's Avatar
I too preferred the Hoosier A6 over the V710. As far as wheels go I did have the same Bullitt wheels but fould them to be very heavy. When I got some new wheels I went with the Enkei RFP1. I forget the price but they were not crazy expensive and you could feel the difference when you picked one up.
Formula Jedi (BM, Hill Climb, TT Special)
LeGrand MK25 rebuild in progress
** Sold **
FFR #5662, MKIII, Carbed 351w,Garrett Turbo,TKO, 8.8 3.55, 3-link, Koni's, VPM Sway Bars, Wilwood Superlites, 17" Goodyear F1D3 Street or Hoosier A6 solo.
P_Matt is offline
post #9 of 11 (permalink) Old 11-08-2013, 06:40 PM Thread Starter
Love this Forum
Thanks Guys, very much appreciate the input, sounds like the A6s are the way to go. Rims I will take a look at the options presented here.
post #10 of 11 (permalink) Old 11-08-2013, 11:47 PM
Thumbs up
poison: Glad to share my experience and try to help. This forum was a find for me after I started to build my car and I knew what I wanted to do and found out here how to do that. Without the members and vendors on this forum I could not have built it the way I wanted it to turn out.
Keep in touch let us know how it turns out:
CB
post #11 of 11 (permalink) Old 11-12-2013, 03:06 PM
Dang, I was excited to see the Enkies but they only have 9.5 and 10 inch widths.
CraigS is offline
