How to remove cone marks from sidepipes - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Competition > Autocrossing / ProSolo
Old 05-02-2012, 08:42 PM   #1 (permalink)
clasim's Avatar
I brushed a few cones this w/e, how do I remove the burnt-on plastic from my ceramic sidepipes?
clasim is offline   Reply With Quote
Old 05-02-2012, 09:02 PM   #2 (permalink)
Cone Basher's Avatar
Talking
If you heat the area lightly with a propane tourch and use fine steel wool to remove it once it gets a little soft it shoud clean up nicely. Also do not put a car cover on your car when it is hot as it also burns and sticks to the side pipes. If you check my screen name you can see I've had a bit of experience with this.
CB
Cone Basher is online now   Reply With Quote
Old 05-02-2012, 09:05 PM   #3 (permalink)
CB
I thought you might weigh in on this.
Old 05-02-2012, 09:11 PM   #4 (permalink)
MJN
MJN's Avatar
Get your Auto X group to buy silicon rubber cones they are softer (less impact damage) and don't melt on the side pipes. I have have finished more than one run with a cone wedged between the pipe and the body without it melting.
Mike....
Old 05-11-2012, 07:04 PM   #5 (permalink)
clasim's Avatar
Thanks Basher,
As I was cleaning one side the thought occurred to me that the same heat that had melted the cones in the first place would be adequate, so I hit the engine and when the pipes warmed up the melted plastic came right off w/the steel wool. Next w/e I'll give the pipes a swipe w/the wool before I head home!
