Ride height - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Competition > Autocrossing / ProSolo
Old 10-09-2011, 12:13 AM   #1 (permalink)
Stoker's Avatar
Ride height
I wonder if a reduced ride height would potentially help autocross numbers. I am presently running 4" front and rear to the bottom of the main tubes. This has become essentially an autocross only car and I don't think any ride height setting would cause tire clearance issues. With that said, why not lower the height? I would think lower CG would only make the car corner better. What do you guys think?
MKIII 302EFI X-cam Power steering. IRS Pin drive width. SAI mod. 750 lb front 900 lb rear Konis. 7/8 front bar. Team III 17X11 17X8. Kumhos. Trick Flow Heads. Edelbrock Victor copy. 75mm throttle body.
Stoker is online now   Reply With Quote
Old 10-09-2011, 01:59 AM   #2 (permalink)
I run 3.5" front and 4.5" rear, measured at the ends of the round tube. Seems to help on the road course.
Old 10-10-2011, 03:07 AM   #3 (permalink)
Stoker's Avatar
I still wonder if lower wouldn't be better as long as geometry isn't affected and the suspension does not bottom out. It takes a realignment for me to try, so I am hoping for anecdotal evidence before having to try it.
Old 10-10-2011, 04:24 AM   #4 (permalink)
On my car, lower ride height increases the bump steer beyond the point that I can adjust for. Not without buying new parts, anyway.
Old 10-10-2011, 06:01 PM   #5 (permalink)
Stoker's Avatar
Good point about the bump steer. I had not thought about that.
