What gun works the compressor more - HVLP or conventional? - FFCars.com : Factory Five Racing Discussion Forum
Old 04-02-2006, 01:06 PM   #1 (permalink)
FFR Master Craftsman
Greg_M's Avatar
Does a HVLP require a larger capacity air supply than the older conventional style guns? Why are painters going to HVLP these days?
Miss August 2007
Miss December 2012
Miss TR6 June 2013
The blues brothers
Old 04-02-2006, 01:19 PM   #2 (permalink)
FredK's Avatar
HVLP uses less air & more paint goes on what you are painting, much less overspray.....
FredK is offline   Reply With Quote
Old 04-03-2006, 07:40 PM   #3 (permalink)
no..... an HVLP in almost all cases uses MORE air and has higher demands from your compressor than conventional guns, you have to check the specs of your gun, some new hvlp are THE most demanding , air wise. but they do have less overspray
you may want to look at a reduced pressure gun, if your used to a conventional the hvlp may require some time to get used to, i use a sata rp.......Vinny
btw there are paint forums on www.autobodystore.com and www.paintucation.com with lots of good info there
Busa*Vinny is offline   Reply With Quote
