What are the typical spring rates used? - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Competition > FFR Challenge Series Discussions
Old 10-06-2011, 11:56 AM   #1 (permalink)
Chepsk8's Avatar
Time to increase my spring rates, still running the stock 250's in back. When pushed hard, the car's rear end rolls more than it should, and make the car over-steer.
Looking for suggestions for just the rear springs, or a new set-up at all corners.
If I recall correctly, the original street spring rate for a MkII with 3-link is 450 front, 250 rear?
I have the tubular suspension part sin front with a VPM sway bar, 3-link out back, no sway bar. Just looking to increase spring rates to get less body roll. On the track, I run the Kuhmo 710's.
Got an extra set of springs?
Chepsk8 is online now   Reply With Quote
Old 10-06-2011, 03:34 PM   #2 (permalink)
cobraless's Avatar
I cant help with your answer as I never ran sway bar. But I have set up lots of spec racers and running high springs works. Doesnt do much for your problem but
here is the part that might help. i have lots of springs in the 500 to 800 range so if someone identifies what you need than maybe I can privide springs.
Dave
No one ... has come up with a drug yet that can match the thrill of driving a race car.
It seems that I run out of driving talent before the cobra runs out of HP!
first start: http://www.youtube.com/watch?v=9s6cA...eature=related
1st time on track sorting it out
http://www.youtube.com/watch?v=ZlIgop1kEnM
cobraless is offline   Reply With Quote
Old 10-07-2011, 10:02 AM   #3 (permalink)
mhoward1's Avatar
most of the challenge guys run between 700-800 front and 450-600 rear. We run 700/500. At the same time though we do not have sways at the moment and those let you run less spring. We also don't drive these on the street very much.
Marty Howard
FFR Challenge #43
2012 NASA SE Champion
2011 NASA SE Champion
Race Team
Become a fan of MH Motorsports
mhoward1 is online now   Reply With Quote
Old 10-07-2011, 10:46 AM   #4 (permalink)
trevor's Avatar
700/350 with ft and rr sways
Old 10-07-2011, 12:26 PM   #5 (permalink)
M DOUGHERTY's Avatar
Std Challange cars are running 750 front and 500 rear.
many will vary the rear rate up or down depending on driving style.
I think you are on the way low side Dan.
The Traveling Builder
717-364-9132 shop
thetravelingbuilder@yahoo.com
M DOUGHERTY is online now   Reply With Quote
Old 10-10-2011, 01:32 AM   #6 (permalink)
Chepsk8's Avatar
Mark,
What would your reccomendations be?
I still run it on the street on occasion, so do not want to be jarred to death.
Old 10-10-2011, 01:13 PM   #7 (permalink)
jimgood's Avatar
The normal recommendation to reduce oversteer is to soften rear springs or anti-roll bars and stiffen the fronts. Why would one increase the rear rate on a challenge series car in an attempt to reduce oversteer? Are the challenge series cars so different from other cars?
"Lotta people go through life doing things badly. Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting." - 1971, Steve McQueen, Le Mans
jimgood is online now   Reply With Quote
Old 10-10-2011, 01:25 PM   #8 (permalink)
Chepsk8's Avatar
The challenge cars have springs that are roughly double the street cars, and I still have the street springs in mine. I am looking to stiffen up the suspension.
Old 10-10-2011, 03:24 PM   #9 (permalink)
jimgood's Avatar
Ok. You said it oversteers because of the body roll when pushed. Hadn't heard body roll being a cause of oversteer. I'm no suspension expert, but my limited understanding is that, when you increase the rear spring rate or stiffen the anti-roll bar, it simply transfers weight faster, thereby increasing oversteer. That's assuming you don't do anything to the front.
Old 10-11-2011, 12:45 AM   #10 (permalink)
trevor's Avatar
with my spring rates the ride is jarring when compared to the spring rates you have. I cant be in my car on the street for more than 15 minutes.
Old 10-11-2011, 12:33 PM   #11 (permalink)
MJN
MJN's Avatar
Dan I run the same springs and shocks as Trevor with Kirkey seats (very little padding) and I think the ride is actually pretty decent. The wife doesn't complain either. Not many pot holes here in NC though so that could be the difference.
Mike....
