FFCars.com : Factory Five Racing Discussion Forum - View Single Post - Fox vs. 94+ vs. FFR control arms
Old 08-06-2012, 12:09 AM   #10 (permalink)
TAnderson
TC COBRA
TAnderson's Avatar
I started out with the fox FLCA, changed the ball joints but I found that the mounting point for the coil over using the existing hole created a clearance issue when the tie rod at full lock. I tried drilling a new mounting hole rearward in the fox control arm but found that the arm needed significant clearancing to fit the mounting bracket. I ended up buying a set from a forum member. I know there expensive but I would really recommend them.
Koni's, Ford Racing 306, air-gap, Holley 600, Mallory Maxfire, 327 grears, big 15 inch meats.
TAnderson is offline   Reply With Quote
