I tried again this morning there is no way to get the tranny far enough back the shifter gets in the way. I will have to remove the engine and install the tranny.
The next qustion the cylinder heads only have bolt holes on the drivers side front and the passenger side rear can i still use the leveler with only 2 pick up points?.
also has any one used the harbor freight load leveler?, they are only 40.00, i hate renting it always seems something breaks then you own it. who else sells a cheap load leveler?
mkIII picked up 9-10-04 completed 9-05 445fe stroker 750 quick fuel q series tremec 3550 irs ffr fuel cell cobra brakes non donor build black no stripes.
