FFCars.com : Factory Five Racing Discussion Forum - View Single Post - roller 351w??
Thread: roller 351w??
Old 03-16-2011, 12:31 AM   #19 (permalink)
joehonee
Leo I don't have much left other than a few of the accesories and brackets but you are welcome to them if you want to pick up the shipping.
What air cleaner do you guys recommend? I would like to run an oval but I am not sure if I will run into some clearance issues with the distributor. I was a bit suprised how much Edelbrock pitches the carb toward the front of the motor.
In a final attempt to stay with the "budget" mentality, I went with the pro products powerfire distributor. It seems that pro products gets a lot of negative press in these parts but I have to tell you that it looks like a nice piece. The advance/retard knob seems like a great idea but I don't have any runtime to give feedback. I did have to order a steel dizzy gear but for $160 total I can't complain. Do you guys think the filter will clear it?
Don, thanks for the input on the kit choices...I might have lined up an 04 Mach-1 as a donor. If I can sell the 32V motor and some of the other parts I might break even and get a Tremec 3650 in the process. I need to find out if the whole donor brake system will run with manual brakes.
Off to do more research and build the piggy bank back up for the kit!
joehonee is offline   Reply With Quote
