While there is some tolerance, I don't think it's an issue. If you
think about it, the engine/trans are bolted in place, the rear is bolted in
place, the only significant movement should be as the rear suspension
moves up and down in an arc. Biggest problem you would run into might
be a small leak where the driveshaft enters the trans?
What's the reason behind the question?
FFR4784CP The FIRST Type 65 Coupe with a "Falk'n Bubble"
99-122 Bright Atlantic Blue S-281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Life is like a dog sled race - unless you're the lead dog, the view never changes...
