throw out bearing always spinning worrries me
Hi Gord,
My throw out bearing is always spinning,
I knew I had this problem from the get go and today I loosened the nut that adjust the fork to the pressure plate fingers from my CNC slave push type cylinder and when the nut was backed up all the way from the fork,I had very little fork play,not enough to back off the fork from the fingers, the fork even loose is touching the pressure plate fingers so it's always spinning,my set up is hydraulic meaning that I have a CNC slave push type cylinder and the tranny is a mustang t-5 original,do you see something here that could cause the lack of freeplay, I don't think I could have installed the fork backwards do to the design, should I investigate more, thanks bud
Michel
