Question about valve adjustment on a 5.0 L HO - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Ask An Expert > Ask Gordon!
Old 08-19-2012, 12:18 AM   #1 (permalink)
ntrudelle
ntrudelle's Avatar
Hi Gord,I'm in the process of adjusting my valves and I'm using the Haynes manual.
They say to bleed the lifter before checking the clearance but I don't have the tool they recommend,it's a Ford P/N,is there any other way to bleed them or I need this tool or equivalent,any idea please,Thanks again !
Michel
ntrudelle is offline   Reply With Quote
Old 08-19-2012, 12:22 AM   #2 (permalink)
Pro FFR Builder and Moderator
Gordon Levy's Avatar
Need a lot more info.
What heads?
What cam?
What rockers?
Pedestal mount or stud mount?
2nd 2005 Nationals
Old 08-19-2012, 12:24 PM   #3 (permalink)
ntrudelle
ntrudelle's Avatar
Sorry about that,it's a bone stock 1990 5.0L HO converted to 570 Holley carb.,Weiand intake.
It's pedestal set up with a bolt on the fulcrum,they say to torque that in a couple steps but I'm not sure what they mean. There is a first torque value and then a second and final.
I put the cyl. #1 at TDC compression stroke for now,I'm ready to go,how do i procede,that book got me confused,thanks Gord
Michel
Old 08-19-2012, 01:00 PM   #4 (permalink)
ntrudelle
ntrudelle's Avatar
As I was reading,I found that they say to tight the fulcrum bolt to a torque value after you install the rocker arm,no specific order,is that ok,thanks Gord !
Old 08-19-2012, 03:03 PM   #5 (permalink)
On bone stock all you need to do is bolt them down and torque to spec. You can put them all on at ones and torque them down.
2nd 2005 Nationals
Old 08-19-2012, 06:48 PM   #6 (permalink)
ntrudelle
ntrudelle's Avatar
I will be doing that right now,I have the torque value and I hope the noise will be gone if they're still noisy could it be that I need new lifters,every internal parts on that engine were used,except for the new piston rings and main bearings,thanks Gordon,have a great day !
Michel
