t5 is out, more questions - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 03-18-2017, 10:22 PM Thread Starter
John Dol's Avatar
I got the t5 out of my coupe due to the advice I received from fellow members. Key for me was to jack the rear end of the engine up from the bell housing. That gave the extra clearance needed to get it out.
Now I have some questions
On the old trans there's a clutch interlock contact that the new one doesn't have. Any idea's on how to tackle that.
Then the tail shaft seal is different but I assume that is no problem?
Also the speedo gear is red. I seem to remember that there's different color gears for different rear end gears. My rear end has 3.73's, is the red gear the right gear?
Thank you,
Building when I can, sigh....
First start Sept. 18 2013
First go kart Sept 19 2013
John Dol is offline
post #2 of 5 (permalink) Old 03-18-2017, 10:36 PM
Rich A's Avatar
7 tooth drive gear (yellow), a 21 tooth driven gear (red), rearend with 3.73 gears, and stock tire diameter.
tail shaft seal with boot Ford, no boot Chevy.
seal specs are almost exact, except one has a boot.
Rich A is offline
post #3 of 5 (permalink) Old 03-20-2017, 02:34 PM
Blues n Brews
ewh123's Avatar
The switch on the top cover is the neutral safety switch. When wired up the trans has to be in neutral to start the engine. If you did not have to unwire it to remove the trans then its not used. If you did unwire it then just splice the wires together in the wiring harness so the engine will start. The other switch on the side is the reverse lights switch. When in reverse its closed to operate the reverse (backup) lights.
ewh123
2006 F5 Roadster #4039, 5.0, 4X4 Headers & Stainless Sidepipes, Holley Ultra 650 Carb, T5, Disc Brakes Front & Rear, 3.73 8.8 4 Link Rear, Chrome Roll Bar And Bumpers, Tubular Control Arms Front And Rear, 17 inch Halibrand replica rims with BF Goodrich Street Comp 2 tires, wipers, Kirkey vintage seats.
2014 F5 Type 65 Coupe #655, 5.0, 2x4bbl carbs, T5, 4 link 8.8, 3.73 gears, tubular control arms front and rear, disk brakes front and rear, 17 inch Halibrand replica rims with 315 rear and 245 front Mickey Thompson Street Comps, wipers and washers, seat heaters, heat and a/c, Kirkey vintage seats, carpet. Still building.
ewh123 is offline
post #4 of 5 (permalink) Old 03-20-2017, 10:41 PM Thread Starter
John Dol's Avatar
Thanks guys.
Guess I'll wire them to a momentary switch so it's a theft deterrent also.
John Dol is offline
post #5 of 5 (permalink) Old 03-20-2017, 10:42 PM Thread Starter
John Dol's Avatar
Oooppsss, cat is out of the bag
John Dol is offline
