Side pipe install advice needed. - FFCars.com : Factory Five Racing Discussion Forum
Old 09-28-2012, 10:23 AM   #1 (permalink)
Fluge's Avatar
How are the side pipe brackets attached to the frame. Are people using bolts that go through and through the frame and body?
I haven't fully installed the side pipes yet and I am wondering if this should be done before I powdercoat the frame so that I can weld the brackets on instead of bolting them on.
Thoughts? How are your brackets attached and are you happy with it?
Marc
It's just a matter of time.
FFR Coupe # 434. Power Brakes, 347ci, Carb, 15 inch Hallibrand pin drive, SAI, 3-link
Fluge is online now   Reply With Quote
Old 09-28-2012, 10:41 AM   #2 (permalink)
Fox2's Avatar
Take the side pipes and have a local muffler shop open them up just a little. My Drivers side was not too bad. The passanger side was WAY off ! It was no fun ! I used the supplied harware and methods. I am about 90% where I want to be. Doing final fitting of doors and hood ......... I will make some minor adjustment to the bracket welded to the side pipes and should get me there.
Fox2 is offline   Reply With Quote
Old 09-28-2012, 01:32 PM   #3 (permalink)
I bolted the bracket on through the square frame, but not the body. Worked good for me.
Hotrod Bill
\'32 Ford 3W Cp w/289-V8 & 3 Holley 2 bl carbs
\'65 Falcon HT w/250-6 & 3-Webers
FFR Type 65 Coupe #345, 347 w/Webers
hotrod bill is offline   Reply With Quote
Old 09-28-2012, 01:56 PM   #4 (permalink)
mmarshall's Avatar
I used self tappers and never had a problem.
Build started - 8 Apr 2008
mmarshall is online now   Reply With Quote
Old 09-28-2012, 02:03 PM   #5 (permalink)
Fluge's Avatar
....So if do the final assembly after powdercoat minus the body, mount the side pipes to the headers, install the frame bracket by bolting them to the frame, take the pipes off, install the body and then re-install the pipes, I should be good to go...right?
My passenger side pipes go on easy but the driver's side headers and sidepipe tubes don't line up well...off by 1/4-1/2 inches ...so ...may need to splay the header pipes apart a little to slide the side pipe on.
The reason I am asking is because the side pipes will be the only thing I haven't fully test fitted before final paint. I made the side pipe holes with a partial sidepipe install and made the holes big enough. I'd like to get the body fully painted now but without fully trial fitting the pipes.
Marc
Old 09-28-2012, 04:49 PM   #6 (permalink)
Grembler2's Avatar
its best to install the brackets with the body on so you can make sure the side pipes are in the correct position. My header pipes had to be either spread apart a little or squeezed together a little to get the side pipes to start going on then its a lot of wiggleing to get them to slide the rest of the way. I also made some marks on the header pipes so i could see how far the side pipes were slid on.
Coupe is complete: 9APR13 9years to build
http://videos.streetfire.net/profile/Tazz49er.htm
http://youtu.be/Wl5drSirMRk
Grembler2 is offline   Reply With Quote
Old 09-28-2012, 06:23 PM   #7 (permalink)
Fluge's Avatar
I haven't looked under the car in that area to know the answer to this....in terms of access...
Can you bolt the bracket through the frame with the body on?
I think I need to make a trip to the body shop and look at a few things...
Marc
Old 09-28-2012, 06:35 PM   #8 (permalink)
master craftsman
Riptide Motorsport's Avatar
Yes you can Bolt the bracket on after the body is mounted .
65 Daytona Coupe
67 Hunter Cobra 427
71 Camaro rally sport
72' 306" pinto wagon 1/4 miler
1973 olds 442
34 ford 5 window coupe
1980 Celica sunchaser.......Google it!
2003 Mustang GT
99 ZX9
85 Goldwing
all cars still in my stable!
next addition ????????????
Fear is the thief of dreams.
Every Saint has a past...every Sinner a future.
Don't take yourself so seriously, no one else does.
You never see a motorcycle parked outside of a psychiatrists office..............
Riptide Motorsport is offline   Reply With Quote
Old 09-28-2012, 10:06 PM   #9 (permalink)
Grembler2's Avatar
I installed mine on the inside vertical side of the 2x2 box tube. Dont forget the isolation rubber if you do use it.
Old 09-29-2012, 02:00 AM   #10 (permalink)
Fluge's Avatar
I had a look under my car and I won't be able to drill (through and through) and bolt the bracket on the inside vertical of the 2x2 with the body on the frame. The body lip under the 2x2 makes it impossible to access the outside vertical of the 2x2. Not sure how Riptide did it.
Am I missing a trick? I guess self tappers with a few spot welds would do the trick too.
Marc
Old 09-29-2012, 02:47 AM   #11 (permalink)
CJBergquist's Avatar
I used revnuts...seem to be strong enough as they stood up to me dropping the car on them....
Chris
If it's too LOUD....you're too OLD!!
Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
FFR#0441CP
Complete Coupe kit, IRS, T-5, 392ci 351W, 4 bbl, ???
Delivered 4/29/09
First Start 3/28/11
Licensed 10/1/12
Finished ????
CJBergquist is offline   Reply With Quote
Old 09-29-2012, 02:51 AM   #12 (permalink)
Fluge's Avatar
Thanks...just thought of that as another option...great minds think alike
Old 09-29-2012, 02:53 AM   #13 (permalink)
Grembler2's Avatar
Rivnuts are fine... you can also either drill and use a fine thread tap or do what i did and use the large rivets
Old 09-29-2012, 02:55 AM   #14 (permalink)
Hi, Marc:
big rivets are the easiest. dont need to worry about access and lots of strength. Make sure you get the spacers right the first time, or you will end up moving the brackets - guess how \I know.
Regards, Mike
hey, 13,500km so far!
Coupe 258, picked up Mar 11-06, The Jones build site
MikeJones is offline   Reply With Quote
Old 10-25-2012, 01:51 AM   #15 (permalink)
EconoCoupe#281
parnelli's Avatar
Hi Marc
I used the 3/16 rivets on the brackets. Have had no problems for 2000 miles.
I even pulled the left side off by catching the sidepipe bracket on a 2 stage curb
( yes I got onto the lot too hot ) with no ill effects. That is except for having to get
the Mrs. to bring me some tools so that I could unbolt the rear bracket from the frame
mount to drive home and do the remedial straightening.
302,T-5,3-Link,Fortes LCA\'s + Rack Offset Bushings, QuickTime Steel Bellhousing,...
parnelli is offline   Reply With Quote
