I need to find the reverse switch.... - FFCars.com : Factory Five Racing Discussion Forum
Old 09-07-2012, 10:11 PM   #1 (permalink)
.... on my Tremec 3550 Road-race II transmission.
There are two small terminals near the center of the transmission on the drivers side. Farther back, there is a connector attached to a couple inches of wire.
I assume the switch is actually inside the transmission and that when the shifter is placed in the reverse position the circuit is closed, allowing electricity to travel, illuminating the lights.
Maybe someone has a photo??
P4CDave is offline   Reply With Quote
Old 09-07-2012, 10:45 PM   #2 (permalink)
Thanatopsis's Avatar
I think it's:
#1 backup
#2 VSS
#3 Neutral safety
You can find a service manual here:
TTC: Product Literature
Peace,
Dave
Thanatopsis is offline   Reply With Quote
Old 09-07-2012, 10:57 PM   #3 (permalink)
The Tremec site shows connector on the tail shaft is Neutral safety.
The one in the center housing is for reverse.
jwall4367 is online now   Reply With Quote
Old 09-08-2012, 01:05 AM   #4 (permalink)
Operability check
I can check to see if there is continuity by running a couple leads to these connections, and setting a multimeter in the Ohms mode. When the shifter is in the reverse position, and there is continuity, then I know my switch is working. If there is NO continuity when the shifter is in the reverse position, then I know I need to replace that switch.
Right?
Can these switches be replaced, and, if so, how is it done?
Old 09-08-2012, 01:24 AM   #5 (permalink)
Speed-crazed and Confused
akdreamer23's Avatar
#1 is reverse switch. Watch out though, those are NOT threads on the prongs. There is a plug that I never was able to find that goes over it. I bought a new switch with attached pigtail from a forum vendor.
#2 is speedo
#3 is neutral safety switch, disabled with a midshift
FFR 6459
Complete kit, IRS, Pin Drive, 408W, Tremec TKO-500, ISIS Power management, PS, hydroboost brakes, paint by Whitby's. ISIS serial # 001, 002 and 003.
Have bled a lot since she arrived....and currently hemorrhaging....but the friends I am meeting along the way sure make up for it.
Graduation Post
http://www.ffcars.com/forums/showthr...=graduate+6459
Build Pictures
http://s325.photobucket.com/albums/k...bra%20Project/
akdreamer23 is offline   Reply With Quote
Old 09-08-2012, 04:15 AM   #6 (permalink)
Couldnt I just..
...run a wire to each of the terminals, hook one to my battery (fuse box), Reverse lights, run to ground, and call it good?
maybe just learn what vendor it was that akdreamer23 obtained his pigtail from and get that part.
I could also just give up. I suspect that the reverselights never did work. I'd rather get it all functioning.
Old 09-08-2012, 07:34 PM   #7 (permalink)
SPeace-ATL's Avatar
The reverse light switch and the Neutral Safety Switch can be simply unscrewed. Some thread sealer will be needed to put it back. Most use teflon plumbing tape.
1965 Mustang Restomod - 5.0 Coupe /MAF/EFI/B303 Roller Cam
5-Speed Specialist - Atlanta!
SPeace-ATL is offline   Reply With Quote
Old 09-08-2012, 09:34 PM   #8 (permalink)
I have a TKO 600 with the same 2-prong reverse switch connection. I got a plug with pigtail from my Tremec distributor - fits perfectly (push-on, not screw threads, as noted below). Don't recall the cost, but it was nominal.
RGHarvey is offline   Reply With Quote
Old 09-08-2012, 09:49 PM   #9 (permalink)
FFR Rookie Craftsman
stengun's Avatar
Howdy,
I have a 3550 TKO trans and I was wondering what was what and I foundthis service manual on Tremec's web site.
http://www.ttcautomotive.com/English...-0711-R1_3.pdf
Paul
stengun is offline   Reply With Quote
Old 09-13-2012, 02:04 PM   #10 (permalink)
I found the problem:
I decided to trace the wires all the way from where they connect to the trans all the way back to wherever they landed. One of the wires was actually broken. The other wire went to ground onto a frame rail.
I hooked the broken wire to a power wire that supplies juice to my fuel gauge sender.
My reverse switch does work! I can tell because whenever I put the trans into reverse my fuel gauge moves from indicating 3/4 full to empty. The reverse lights still dont light.
The GOOD news is that I know my tranny switch works.
I disconnected the trans switch wire from the power source, and now I am waiting for an electritian friend of mine to rescue me. We are so so close to fixing this..... I can just feel it.
Old 09-13-2012, 11:44 PM   #11 (permalink)
Gopher's Avatar
Call Mike at Forte's he has the switch and the plug you need .I got the one for my Trans through him. He's great to deal with as well.
Anniverary Edition,Dart Aluminum 427, TKO 600, ISIS, Bump steer,5 link,,Billet upper,lower control arms ,Wilwood six piston brakes front four piston brakes rear,Russ Thompson's turn signal and throttle pedal,Stainless Steele's 427 headers,Fast Freddies Steering.
http://www.ffcars.com/forums/members...s/28242-gopher HTTP://photobucket.com/annivesary-car
Gopher is offline   Reply With Quote
