Not sure of the best answer as I'm no expert, but I prefer the screw type terminals since it make a solid connection that won't come undone - used small lock washers on them.
Switches are rated for current so I typically used medium duty for my milliamp switches (I-squared) and heavy duty for anything that is going to carry 12V.
I use screw terminals. But I'm an AR engineer type.
Look at the amp ratings and match them to the current draw of your circuit.
I tend to buy aircraft quality switches. Pricey but you'll not have to worry about pulling a panel to replace a failed unit.
Most of your switches will probably be SPST. My hazard circuit uses a DPST.
“Debugging is twice as hard as writing the code in the first place.
Therefore, if you write the code as cleverly as possible, you are, by
definition, not smart enough to debug it.” -- Brian Kernighan
Peace,
Dave
I prefer the blade terminals. easier to install and remove.
SPST = single pole single throw. Good for on-off of one circuit
DPST = double pole single throw. Good for on-off of two circuits
SPDT = single pole double throw. Good for one circuit such as on-off-on.
If you Google switch terminology, you can get a more definitive answer.
For my upcoming Roadster build, I'm using Cole-Hersee toggle switches rated at 25A
Bill D
RCR GT40 - 1051P clone, $old
I use Cuttler Hammer from McMaster Carr. Metal bat handle toggles just like NASCAR.
I use 0.250 spades and AMP crimp lugs.
These lugs work very well PROVIDED YOU USE GAGE APPROPRIATE LUGS.
I have used for years at a famious musical instrument company known for reliability and safety.
Build started 15 Dec. 2002
