SN95 or Fox length..Which is best for the coupe? - FFCars.com : Factory Five Racing Discussion Forum
Old 07-21-2012, 10:30 PM   #1 (permalink)
Jetsbaby's Avatar
Title says it all..I currently have a 1994 Mustang rear that needs to be rebuilt..I am sitting on the fence if I should go with new Yukon Fox length axle or stay with the SN95 that is currently on the rear end..I do like the .75 inch more on the SN95. More width more stability??..But I want to go with a 4 piston Wilwood rear brake system and ALL of the four piston kits are for FOX width and not SN95..I could shim the brake caliper out more by .75 inch but I don't think that its the smartest thing to do..This will be 90% used track car so I really don't want to risk having a rear brake failure at speed..UGGH!
Jetsbaby is offline   Reply With Quote
Old 07-22-2012, 12:25 PM   #2 (permalink)
Richard Oben's Avatar
It all depends on wheels. If you want to use stock style mustang wheels on the coupe then keep the SN95 width. If going with custom width then the deeper dish from the FX track looks better. The fronts are always an issue as the body is wider than the standard 9 inch wheel most run. HTH, Richard.
Richard Oben is online now   Reply With Quote
Old 07-22-2012, 01:45 PM   #3 (permalink)
mn12's Avatar
Here is a photo of mine with an 02 mustang axle and the stock 17" wheels
Type 65 Coupe 531
02 Modular Donor Build
mn12 is online now   Reply With Quote
