Which Pedal Assembly is best to use w hydroboost? - FFCars.com : Factory Five Racing Discussion Forum
Old 07-15-2012, 04:50 PM   #1 (permalink)
THEDON's Avatar
When going with a hydroboost setup which is the best year pedal assembly to use? I did search but didn't find a definitive answer.
The reason I ask is listed below.
I knew that by putting in a 4.6 SC terminator motor I would be running into a lot of issues and here's the latest.
I was using the wilwood dual MC pedal assembly and think for manual brakes it is probably the best on the market and I was fine with manual. I had planned on using hydraulic clutch since it was setup for that anyhow. I have the complete TKO hyd clutch kit but it doesn't fit with the 4.6 bellhousing which has the hole clocked in the 7 o'clock instead of the fox mustang 9 0'clock. So instead of re-engineering my SFI steel bell housing I am going to go hydroboost and mustang pedal assembly with clutch cable.
Miami, FL
65 Coupe #439, Complete Kit, 3 Link, Terminator Cobra Motor, TKO 900
THEDON is offline   Reply With Quote
Old 07-15-2012, 07:45 PM   #2 (permalink)
The 94+ would be your best choice. It will bolt right in and was used with the hydraboost system. The 87-93 will also fit, but you might need to enlarge a hole or two with the hydraboost.
Old 07-16-2012, 02:59 AM   #3 (permalink)
THEDON's Avatar
Thanks Mike, I bought a 2003 pedal assembly, adjustable clutch cable (ford racing), and a used hydroboost assembly.
I need to get a clutch fork and pivot ball now, I don't think my fox body fork will reach (short).
Luckily my friend just went from manual brakes and steering to hydroboost and PS with a proportioning valve on the front brakes. He has the cobra brakes the same as mine basically (mine are pbr his are cobra lettered).
So we can sort it out on his car long before mine in in go cart.
Miami, FL
