Ride height and day-to-day use - FFCars.com : Factory Five Racing Discussion Forum
Old 05-01-2012, 05:09 AM   #1 (permalink)
I'm not fat, I'm Robusto!
Spaceclam's Avatar
So I'm running the 15" rims, which mean larger sidewalls which overall mean bigger tires. This car will be a daily driver, for those of you not familliar with my extensive modifications.
Initially, I set my ride height at 5.5 and 6, which I knew to be high, but I wanted to minimize any issues associated with bad intersections, steep driveways, etc.
I decided it looked stupid and lowered the back down, giving me 5.5 all around.
But it still looks high. Will I have any clearance issues running 5" front and rear? I am running slightly softer springs on my car (50# less, front and back, which comes out to about a 12% reduction)
I know many of you run less than this and "have no problems" but most here aren't daily drivers either...
Coupe 507
Spaceclam is offline   Reply With Quote
Old 05-01-2012, 06:47 AM   #2 (permalink)
TNcoupe's Avatar
Clam, I say leave it where its at right now. Between getting paint on mine and when I really started driving it last fall mine settled about 1/2" on both ends. Let it settle then adjust accordingly.
Complete Coupe #485
Delivery to first legal drive in one year
5/12/10-5/12/11
Belize blue pearl with Arctic White stripes
331ci, T5Z, .79 5th gear, Wilwoods, and 3 link with 3.73s
TNcoupe is offline   Reply With Quote
Old 05-01-2012, 04:21 PM   #3 (permalink)
mmarshall's Avatar
I have been running 3 3/4" for 3000 miles and have never hit the frame once. Alot depends on the depth of your oil pan and bellhousing. My Champ pan was above the frame rails but my quicktime BH was about 1/2" lower than the frame. When I removed it all the powdercoat was still on the bottom. Considering my 3 3/4" ride height I was suprised it had never touched once.
Build started - 8 Apr 2008
mmarshall is online now   Reply With Quote
Old 05-01-2012, 05:33 PM   #4 (permalink)
Spaceclam's Avatar
Im actually concerned about scraping the nose on a driveway or crappy intersection.
Coupe 507
Old 05-01-2012, 05:39 PM   #5 (permalink)
mmarshall's Avatar
The 2 scrapes on my nose came from pulling too far forward in a parking space. The nose is deceiving in how long it is. I have yet to hit on a drive entry, but I take them at an angle.
Old 05-01-2012, 05:45 PM   #6 (permalink)
2FAST4U's Avatar
My Roadster was set to 3" in the front and 3.5" in the rear. I did have problems with speed bumps, but it looked way cool!
Bill D
RCR GT40 - 1051P clone, $old
289 FIA currently in work with Mr. Bruce, 331, dual quads, T-5, and IRS
http://www.bills289fia.com
Old 05-01-2012, 06:17 PM   #7 (permalink)
I am at 4.75" in the rear, 4.5" in the front. At this height, the frame just clears a hump in my driveway. No problems with speed bumps . . . so far.
Mike Monroe is offline   Reply With Quote
Old 05-01-2012, 08:43 PM   #8 (permalink)
Bill Hughes's Avatar
I am at 4.5 inch front and rear. Only issue is parking lot curbs. That problem is a driving skill issue.
I have been to the weekly car show at the Scottsdale pavilion and have seen one OUTRAGIOUSLY high SPF, must have been 6 inches!!
Build started 15 Dec. 2002
Old 05-02-2012, 12:28 AM   #9 (permalink)
I'm at 4" front 4.5 rear. I've have had no problems with speed bumps or driveways but I have a couple of scrapes under the nose (they don't show unless you crawl underneath). The scrapes came from curbs which is a driver issue, which someone else already addressed. I also have to use additional 6' ramps when loading into my trailer. I have 24,000 miles with out clearance issues and I do go down dirt roads which are quite common here but with care.
Roy
Type 65,#181, IRS, pin-drive, 17" PSE wheels, Michelin 275F/335R , 347/425hp,TKO 600. Toyota/Lexus spectra blue/cosmic silver. 24,000 miles in 4 summers--a driver!
Roy Hewson is offline   Reply With Quote
Old 05-02-2012, 04:06 AM   #10 (permalink)
allbite's Avatar
I have my front and rear at 4.5, and I have a sloped driveway.
If I go up it real slow I'm fine. If I go up with any speed the nose rubs.
Not to mention, I also have that driver problem the others mentioned with curbs.
________________
www.allbite.us
Coupe 413 Delivered Aug. 26th 08
allbite is offline   Reply With Quote
Old 05-02-2012, 12:30 PM   #11 (permalink)
theboppshop's Avatar
Ditto on the nose scraping a curb ... oops! I'm running 3.5" front and rear. I have bottomed on the Quicktime scattershield on occasion. I take speed bumps at an angle and no problem there.
Garry
The Bopp Shop
Coupe # 031 with 422" Windsor by Southern Automotive (dash autographed by Peter Brock)
Mk III # 5021 (SOLD)
Unique 427 Roadster with 482"FE by Southern Automotive
theboppshop is offline   Reply With Quote
