Im also useing a mustang pedal box. I took the quarant [plastic crap] off and turned the shaft 180 deg then put the pedal back on. Then mounted a tilton master cyl on the firewall. Hooked it up with a clevis and pin after drilling a hole through the part of the clutch shaft the plastic crap was on. The only problem with it is a brake booster will not fit past the master. Sorry about no pics. We didnt go on the forum until we were done and never thought about them.
Wayne
MK3,FE427-6V,TKO,IRS,Dual Heaters,Heated Seats
