I knew I should have........ Please Don't make my mistake. - FFCars.com : Factory Five Racing Discussion Forum
 8Thanks
  • 1 Post By Big Blocker
  • 1 Post By Chuck_Sloggett
  • 1 Post By 5.8Cobra
  • 1 Post By srells
  • 1 Post By Michael Everson
  • 2 Post By JKleiner
post #1 of 14 (permalink) Old 06-18-2017, 11:29 PM Thread Starter
DadofThree's Avatar
I knew I should have done it, but I didn't! Stupid me!!
Well. I knew I should have put gasket sealant when replacing the freeze plugs! I didn't at the time that I did it, but I did read about it while the motor was still in the stand. But I had just painted it (my pathetic excuse). I'm sure it will be fine, blah, blah, blah!
I pressure tested the cooling system today, and ready to give it a drive this week!! But instead, I found a water spot under the motor. It's coming from the freeze plugs that I replaced and didn't put sealant with the plug. Now I need to redo, all because of my laziness. It looks like I'm going to need to pull the motor to do it correct! One of them are between the motor mount bolts into the block.
Please don't do what I did. Take the extra step everytime you have the chance. Learn from my mistake. I feel like such a dumba$$. Frustrated with myself and embarrassed.
What's your "I knew I should have" that we can learn from you?
Dave
Dave
My photos are at:
Videos are at:
Loving the Island Life
DadofThree is online now
post #2 of 14 (permalink) Old 06-19-2017, 12:45 AM
Red face
we have all done things like that. Or at least I have.
Last week I put a new water pump in my rough old '79 Ford truck. I did not take the time to clean and silicone (RTV) the three long bolts that go thought timing chain cover. Crank the motor and let it run for 20 minutes. Small drip from one of the bolts.
Yesterday I pulled the fan shroud and fan off so I could do it correctly. Also had to remove the brackets that held the alternator and power steering pump. Got RTV on a good t-shirt.
Dwight
DWIGHT is offline
post #3 of 14 (permalink) Old 06-19-2017, 01:36 AM
Official OLD GUY
Big Blocker's Avatar
Wait . . .
Dave,
Wait a bit before you jump right in to pull the engine out to replace these freeze plugs. If you have other things to do [to the car] that won't get in the way of removing the engine down the line, do those things now.
Freeze plugs have a way of rusting internally and sealing themselves up with no participation from the guy(s) that didn't use sealant . . .
Most cars, the one behind the mount is do-able but in our cars, maybe yes, maybe no. And - that's if you have the proper tool for installing freeze plugs.
FWIW, when I worked for FORD, we never used sealant . . . just knocked the old ones out and replaced with new ones. We were on a clock and pressed for time. Not sayin' it's right but never had a car return with a leak. We didn't have the luxury of pulling the engine out but did have the installer tool.
Doc
DadofThree thanked this.
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #4 of 14 (permalink) Old 06-19-2017, 01:50 AM
Chuck_Sloggett's Avatar
I would consider a bottle of radiator stop leak if the leak doesn't seal up on it's own. -- Chuck
Mark 4 FFR 8687 3 link, Konis, tubular LCA's, Carbed 347, AFR 185's, Comp HR274XE Roller Cam, T-5Z.
Gas'N stainless headers and side pipes, 3.55 rearend, Hydroboost, SN-95 spindles, 4 wheel disc brakes, Power steering, Classic instruments, Competition style dash, Guardsman Blue w/ Wimbledon White stripes, heated seats, heater, etc.
Chuck_Sloggett is offline
post #5 of 14 (permalink) Old 06-19-2017, 02:02 AM
5.8Cobra's Avatar
I have replaced them in the car, at least one or two, and one was behind the motor mount. I just lifted the motor with a block and jack and took out the mount, banged it in and hasnt leaked since. The plugs you have there look like the shallow ones, maybe look for some with twice the depth since they have twice the surface area to seal. I dont usually use sealant when installing either. You could try some green loctite, it wicks into the space and hardens, the guys at the shop use it whenever they weld sumps on gas tanks or anything else they want to be double sure it wont leak. Its worth a try. Good Luck getting back on the road.
FFR 3107 Built & Sold
FFR 1990 Built & Sold
FFR 7330 Built & Sold
5.8Cobra is offline
post #6 of 14 (permalink) Old 06-19-2017, 03:54 AM
srells's Avatar
I replaced 3 on one side in the car. Just need to get the install tool, was not a big problem
302 w 351w heads, 600 holley, dual point, IRS, PIN DRIVE, DELIVERED 12/12/06 FIRST START 4/15/07 8 miles on gocart 5/5/07 Licensed 6/20/09, Insured 3/14 Stripe Sunlit Gold Metalic Body lexus Spectra Blue Mica 8m6
srells is online now
post #7 of 14 (permalink) Old 06-19-2017, 10:16 AM
I second the high quality sealer. GM LS motors came pre packaged wit the stuff. Ask the GTM guys that bought crate engines.
Michael Everson is online now
post #8 of 14 (permalink) Old 06-19-2017, 10:55 AM
I'm with Doc, Chuck and Mike. Before getting too deep try a sealer. Back in the day this was "the good stuff" (like me Doc probably remembers when it was in the little yellow and black metal can):
https://barsleaks.com/product/pellet...uty-stop-leak/
Nothing to lose but a few bucks by giving it a try Dave. Be sure to follow the rules and let it get to full operating temperature.
Then and now I always put plugs in with brush on Permatex Form A Gasket (or for another throwback that I'm sure my friend Doc will recognize...Indian Head Gasket Shellac!).
My "I knew I should have..." story---I knew I should have never married that first one
Good luck,
Big Blocker and DadofThree thanked this.
JKleiner is online now
post #9 of 14 (permalink) Old 06-19-2017, 12:32 PM Thread Starter
DadofThree's Avatar
Thank you for the advice, recommendations and sharing what you have done in the past.
I didn't do any more work on the car yesterday after finding my leaks (there's also one in the water pump/timing cover surface).
I'll update later. I'll definitely continue working forward and try to get a lot of other items done.
Dave
My photos are at:
Videos are at:
post #10 of 14 (permalink) Old 06-19-2017, 01:34 PM
Formulagod's Avatar
Originally Posted by DadofThree View Post
Take the extra step everytime you have the chance. ]
Required step, not extra!
MKIV-Coyote-Wilwood setup-Hydroboost-17" Halibrand-3 Link-TKO600 FFR #8214 Under Construction
Formulagod is offline
post #11 of 14 (permalink) Old 06-19-2017, 02:03 PM
Official OLD GUY
Thumbs up Blast from the past
Jeff,
Thanks for the Indian Head Gasket Shellac! blast from the past.
I had a good laugh remembering all those Old School things we did back then.
Doc
MCathcart thanked this.
HUMMMMMMM?
post #12 of 14 (permalink) Old 06-19-2017, 03:33 PM
Doc
But they worked didn't they? As Jacob the Amish I.T. guy says while whacking a computer with a wooden mallet..."Sometimes the old ways are the best ways"
post #13 of 14 (permalink) Old 06-19-2017, 05:57 PM
What - nobody uses black pepper anymore???
Blair
FFR 4676K 2003 MKII completed 10/13 by others
302 Donor build,heater,VPM Coilovers, Charcoal Gray with Pepper Gray stripes,King Cobra Clutch, Custom shifter,65mm AccuFab Throttle Body,EGR Delete,75mmMassAir,GT40 Tubular Intake, Edlebrock Aluminum Heads, TW Cam-and it ain't finished yet!
g8rnbft is offline
post #14 of 14 (permalink) Old 06-19-2017, 08:10 PM
phileas_fogg's Avatar
Or as my Army colleagues say, "If it's stupid and it works, it's not stupid."
MK IV Roadster #8631
phileas_fogg is offline
