Video showing My FiTech GoStreet EFI 400 Wiring - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 05-26-2017, 03:51 PM Thread Starter
DadofThree's Avatar
Last night I spent the time wiring up my FiTech and thought I'd share with you what I did. It's probably a better idea to do this after a clean start, but none the less.....Please take a look and tell me if I've done anything wrong.
Thanks.
Dave
Dave
My photos are at:
Videos are at:
Loving the Island Life
DadofThree is online now
post #2 of 5 (permalink) Old 05-26-2017, 09:45 PM
Nice video, just finished this install today. I used the choke wire for the key-on power like you are considering since it was already up next to my carb.
I also used the RF fan control wire that was on the intake since all it does is ground the relay when it reaches temp, which is the same function that fitech does.
I have a diff ignition set up than you, so I pulled the tach off the back of the tach, which is fed from an MSD box. fitech says this is okay to do.
Red power wire went to the battery feed that goes to the key, since it was right there and easy to tap into.
Fuel pump power - was gonna run it back to the tank direct to use modulation feature, but didn't want to tear apart my tunnel harness. I just ran it to the pump relay in the fuse box as designed in the RF harness.
Turned the key and it worked, so I can at least confirm that you are good to go on the choke wire part! Good luck this weekend!
Keysergogo is online now
post #3 of 5 (permalink) Old 05-27-2017, 01:17 AM Thread Starter
DadofThree's Avatar
I'm glad to hear you had a successful go at it. I too did the suggested step by RF for the EFI controlling the pump this evening. I cut the little pig tail located at the relay and attached the orange wire to it.
Dave
My photos are at:
Videos are at:
post #4 of 5 (permalink) Old 05-27-2017, 02:53 AM
brian1967's Avatar
Looks good Dave. When I connected the Fitech 12 volt input lead to the starter I had a problem where the Fitech screen would go black upon cranking and I would have to unplug the controller pigtails at the controller to bring it back up. Fitech tech line told me it needs to go directly to the battery. I did just that and problem solved. And that vacuum nipple on the passenger side of the throttle body is for fuel pressure boost refrence, used only if your running a turbo or supercharger. leave it open since your not going that route, don't even cap it.
Remember to have the o2 sensor plugged in before you turn the key, Fitech states it can damage the computer if left unplugged. ( even just with the key on and not running).
Good luck, I cant wait for the video.
brian1967 is offline
post #5 of 5 (permalink) Old 05-27-2017, 09:33 PM Thread Starter
DadofThree's Avatar
Note: I didn't habe spark until I ran the orange efi crank wire to the positive coil post. Also, I ended up skipping the fuel pump relay and hardwired the orange fitech wire directly to the fuel pump wire. Then we got fuel.
