Oil port, 302, before or after filter? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 8 (permalink) Old 05-19-2017, 03:18 AM Thread Starter
Spaceclam's Avatar
Hi Everyone,
On the SBF, there is an oil port right next to and in front of the oil filter on the left hand side. Is this port before or after the oil filter?
-Andrew
Coupe 507
Spaceclam is offline
post #2 of 8 (permalink) Old 05-19-2017, 05:08 AM
Pro FFR Builder and Moderator
Gordon Levy's Avatar
The out is the offset port and the in is the center. Out into filter outer and in through the center
2nd 2005 Nationals
Over 180 Turnkey FFR's in 20 years and still counting
Gordon Levy is online now
post #3 of 8 (permalink) Old 05-19-2017, 05:25 AM Thread Starter
Spaceclam's Avatar
No, I mean the 1/4 npt threaded port just forward of the oil filter. Is that located before or after the filter in the oil system?
Coupe 507
post #4 of 8 (permalink) Old 05-19-2017, 05:32 AM
That is usually the oil pressure sender port.
2nd 2005 Nationals
post #5 of 8 (permalink) Old 05-19-2017, 03:01 PM Thread Starter
Spaceclam's Avatar
Yes, that one. I have my sender attached to that one.
But the question is this:
Is that sender port located upstream of the filter (as in, reading the pressure between the pump and the filter) or downstream of the filter (as in, reading the pressure that the engine components see after the loss in the filter)
Put another way, if an oil filter becomes clogged or the element fails, does the oil pressure go down (because sender is downstream of the filter, the oil is being blocked by the filter, so there is less pressure to the sender and engine components) or does it go up, (because the sender is reading pressure before the blockage)
-Andrew
Coupe 507
post #6 of 8 (permalink) Old 05-19-2017, 03:09 PM
Official OLD GUY
Big Blocker's Avatar
AFTER . . . Google [images] "FORD 302 oiling system"
Doc
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #7 of 8 (permalink) Old 05-19-2017, 03:22 PM
it is after, everything goes through the filter first
2nd 2005 Nationals
post #8 of 8 (permalink) Old 05-19-2017, 10:30 PM
Cool
That is good to know.
Blue Horse
bluehorse is offline
