Bellhousing to the drive shaft - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By Bobby Doug
  • 1 Post By CraigS
post #1 of 5 (permalink) Old 05-16-2017, 01:59 AM Thread Starter
Just bought a 408 cu.in. 425hp / 455tq from Blue Print Engines , saw them at the Huntington Beach FFR show last month . still need to purchase Bell-housing , Flywheel , Clutch & pressure plate , TKO 600 , and drive shaft ! Reaching out for recommendations on what parts to purchase and where to buy them ( any deals out there ), definitely don't want a heavy clutch ,Thanks for all your HELP
DAN 50 is offline
post #2 of 5 (permalink) Old 05-16-2017, 10:38 AM
Call Mike Forte. He is an advertiser on the forum.
DAN 50 thanked this.
FFR7995
MK IV
Prestige Motorsports 347 SBF, Moser 8.8 (3.31), 3 link, TKO 600,hydraulic clutch, PS, Heat/AC, 17" Halibrands, Nitto 555s,
Bobby Doug is offline
post #3 of 5 (permalink) Old 05-16-2017, 11:16 AM
Be sure to check w/ Blueprint Engines on how they balanced the crank. Once you move into stroker kits some are zero balanced.
CraigS is offline
post #4 of 5 (permalink) Old 05-19-2017, 06:38 AM Thread Starter
Yeah I called up Blue Print engines and they said I needed a 28oz. flywheel cause they had already supplied me with the harmonic balancer , Thanks I'll also be talking to Mike , I've already been in contact with him re: other parts I've purchased from him ! Thanks for the imput
DAN 50 is offline
post #5 of 5 (permalink) Old 05-19-2017, 09:18 AM
CDXXVII's Avatar
Billet Steel Flywheel
Fortes would be a good source for the clutch. I went with the McLeod Twin Disc but I'm not sure I would recommend it.
I believe this is a good flywheel for your application.
Ford Performance Parts Flywheels M-6375-A302B - SFI rated
https://www.summitracing.com/parts/f...view/make/ford
Don't forget the bolts - ARP-200-2802
https://www.summitracing.com/parts/arp-200-2802
This is a good bellhousing for your application - Non SFI (but meets sfi standards for your safety) - Does not hang below the frame.
QuickTime Bellhousings RM-6060
https://www.summitracing.com/parts/q...view/make/ford
First Start 05/23/2015
First GoCart 05/23/2015
CDXXVII is online now
